Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I recive\system 32\hal.dll
Hi there, I need some help for my PC. It doesn't start normally, it says you need:\system 32\hal.dll, I have to tell you I wiped by mistake shell extension and restore does'nt work. On my desktop only my dokuments can open and I'm using that page to get on this internet. Thank you Adi from albania.
    Scholar:
  • 81 Answers
The first thing to check is your boot order.. do this when the pc starts up by pressing which ever key is indicated to enter 'setup' usually f2, f12, or delete. and look through for boot devices or boot sequence. make sure it's floppy, cdrom, hdd drive which may be listed or hard drive, internal drive, etc).
Do you have your windows disk? If so try this... put in the cd and restart the computer and when prompted to "pressany key to boot from cd' do so. Enter Windows XP Recovery Console by click on R. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
  1. When you reach the command prompt type the following command and then press Enter.
  2. bootcfg /rebuild
    The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
  4. Type Y in response to this question and press Enter.
  5. The next prompt asks you to Enter Load Identifier:.
  6. This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  7. The final prompt asks you to Enter OS Load options:.
  8. Type /Fastdetect here and press Enter.
  9. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
  10. Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Posted on Dec 02, 2008
Reinstall windows root system 32 hal.dll
Do a start up repair.
Insert your Windows Operating System disc in the DVD. Reboot your computer and press any key when you see the phrase "Press Any Key to Boot in CD".
Select the start up repair and it should work after the loading process.
I hope this helps.
Carlo
Jan 23, 2013 | Dell Inspiron Computers & Internet
Sometime after installing some cd which came with a childrens interactive book, I received a message saying Windows could not start because the following file is missing or corrupt: <Windows...
There are about three things that might have happened. They're all mentioned at the following link:
https://neosmart.net/wiki/hal-dll-missing-corrupt/
Any Windows CD of the exact same Windows version can be used if you decide to try that route. You're really just looking to repair Boot.ini or hal.dll
Oct 02, 2017 | ZT Group Cisnet PC Desktop
Have acer aspire one, when started got screen saying file missing or corrupt window root system 32 hal.dll, nothing else cannot bring up safe mode do not have windows xp cd, in nursing home cannot afford...
I am going to start with the assumption you have already tried to reboot, then next choices from there go kinda like this...
Run windows XP restore from command prompt. (From safe ,mode type C:\windows\system32\restore\rstrui.exe and press Enter. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
Replace the boot.ini file (run msconfig) This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
Right click on c: drive, click on properties, then tools, click on the error checking button, the put a checkmark in each box, Click start and it may say it needs to run on next reboot click OK the reboot. The physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
Run a repair install of the operating system. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
Nov 29, 2010 | Computers & Internet
Windows not start.They say: Reinstall <Windows root>System32/hal.dll.Where can I find this disc?
hi,
HAL.DLL stands for Hardware Abstraction Layer.
It is a Dynamic Link Library that connects to Kernal and Hence your Harware can talk to the software.
The File is available in the installer Disk with some similar name as Hal_ or Hall_.
But Honestly saying, try a safe mode to get to the desktop. Recover as max data possible from your desktop amd documents or my documents to a simple folder saved on a thumbdrive.
Repair the OS.
and check for the stability for say a week. if everything comes back to normal. Its good. else contact me .
Write a comment and vote me to keep in touch!
Bye for now.
Sep 13, 2010 | Dell Computers & Internet
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
\system32\hal.dll. MISSING FILE
YOU NEED TO DOWN LOAD THIS PROGRAM FROM MICROSOFT.
WWW.WINDRIVERS.COM/HAL.DLL
OR
WWW.WINDRIVERS.COM/SYSTEM32/HAL.DLL
ONLINE ADDRESS BAR: WINDOW DRIVERS FOR SYSTEM32\HAL.DLL
OR FIND THE FILE IN THE ORIGINAL SOFTWARE YOU INSTALLED THE WINDOWS VERSION ONTO THE SYSTEM
ROD
Feb 12, 2009 | Acer Aspire 5000 Notebook
Hal.dll
Here is a kink that will give you steps to tak to correct this HAL.DLL issue:
http://pcsupport.about.com/od/findbyerrormessage/a/missinghaldll.htm
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 16, 2008 | Toshiba Satellite M45-S331 Notebook
Deleted dll
BOOT FROM YOUR WINDOWS DISC AND CHOSE OPTION RECOVERY CONSOLE AND USE THE GUIDED HELP...BUT FIRST DOWNLOAD THE MISSING FILE AND COPY IT TO WINDOWS 32 SYSTEM FILE FOLDER.RICHARDM69
Dec 01, 2008 | Dell Dimension 8100 PC Desktop
Compaq pc recovery problem
hal.dll is a dynamic-link-library.
Not necessarilly a part of your operating system.
could be a printer or other peripheral device driver.
try re-installing all of your other hardware device drivers.
Mike @ compurepair.
Apr 04, 2008 | HP Compaq Presario V6000T Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
