Question about PANDIGITAL (DPF802) Digital Picture Frame
My pandigital frame no longer displays anything. You plug it in and it's a blank screen
  • 3 more comments
  • michelle169 Dec 10, 2008
    blank screen
  • moram Dec 27, 2008
    I have 9" pandigital frame. i get the power. But no pictures. Any solutions?
  • bea1124 Jan 10, 2009
    I have the same problem. Sometimes the power goes back after a couple of tries but everymorning when I want to turn it back on it's dead
  • Bernettadoug Jan 11, 2009
    I have a Pandigital frame that has a black screen as if it is not getting power. I have checked the power and there is power but the frame does not come on. NOTHING Could the LCD burn out and if so is it repairable?
  • fdbrunette Jan 17, 2009
    same thing. used it once. unplugged it to move it and now it won't turn back on.
    Problem Solver:
  • 6 Answers
If you have an all grey screen than the frame is dead --- which menas throw it away. Check voltage on the power supply. Make sure voltage matches the output on the power supply. Also try connecting it tto the computer and formatting the internal memory.
Posted on Dec 11, 2008
My sreen for months hs been stuckon screen that says androidsystem recover
Try the simple stuff first ... turn the picture frame off. Then remove the AC power adapter from the a/c socket in the wall. Wait 30 seconds then plug the adapter back into the wall outlet. Turn your picture frame back on and notice any error messages that may get displayed.
Jun 06, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Pandigital net support
Contact the original vendor
Aug 09, 2017 | Photography
My pandigital photo frame doesn't work at all. When plugged in the screen says System Start. That's all I get.
This frame cannot initialize; this is an internal memory issue. Connect the frame to your computer with the USB cable and to the AC outlet. Now turn it on. Under Computer or My Computer, look for a Pandigital (X:) drive.
If you see that drive, right click on it and select Format.
Choose FAT or FAT32 as the file system, check Quick Format, then Start.
Once it finishes, unhook the frame and restart it.
If you do not see that drive, your frame is toast. Grab your receipt and return to the store or call the company.
Jan 02, 2010 | PANDIGITAL 7" Digital Photo Frame With...
Pictures are cut off! Just got a 8 inch Pandigital photo frame for Christmas and loaded pictures on it. Since it does not have auto-rotation, I manually rotated any pictures that needed it before I put...
The frame is cropping the images to fill the screen. You need to change the image display settings from Optimal to Original in the setup menu. This way the entire image will show.
Dec 30, 2009 | PANDIGITAL 8.0" Digital Photo Frame...
Unable to bring up the setup screen for display option
can't get the frame to cut off and start back up to show the setup program
Apr 02, 2009 | PANDIGITAL PAN80-2 (892235000548) Digital...
''remote is temporarily inoperative''
Sounds like you have it plugged into the computer via the mini usb connection. When plugged in this way, it functions like a thumb drive... a quick way to load pictures to the frame from the computer. Try unplugging the USB cable...
Dec 27, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
PANDIGITAL (DPF802) Digital Picture Frame Logo
820 people viewed this question
Top PANDIGITAL Photography Experts
Gareth Cockram
Gareth Cockram
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
