Question about Acer Aspire 5100 Notebook
System does not see hard drive all of the time
The machine does not always see disk 0. When machine starts up if it does not see the hard drive it beeps two times and asks me to touch f1 or f2. If I use f2 then sometimes it will boot afterwards. This is not always the case, if I replace the hard drive then it will work for a while then the same problem comes back. If I put the first hard drive in the machine it works again as it should for a little bit then goes back to does not see drive 0 and we start again by changing the drives. There must something lose or a problem with the motherboard. Are there any fixes for this?
When looking at the bios it sees the drive and sometimes after going to f2 the machine will boot as it should. Today when it stopped working I only removed the screws for the cover of the hard drive and now it works just fine. I have tried changing the memory as that can mess things up as well.
  • Anonymous Dec 03, 2008
    I am experiencing the same problems. I have removed the hard drive and the battery numerous times and it still won't boot. Probably a loose connection on the board somewhere but where who knows. New board is $225+, new laptop may be the way to go.
  • 340 Answers
It sounds like a loos connection.
Power off, remove tha battery.
Carefully remove the HDD, and just as carefull reinstall it again.
Regards
/Teis
Posted on Dec 02, 2008
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
I have a compaq m2105us and when i start it all i get is two beeps and a resume f1 and start f2
try to press f1 and resume set-up ..and make the changes for teh date and time ..and save all settings with F10 and restart ..it should work ..and load windows if it has one ..The fact that it let you go in bios is good news..it means it is not damaged but if it asks all he time f 1 to resume ..it means the hard disk may have bads on it in system check ..and this is causing the f1 call ... basically the systems tells you that you have a bad hard disk and invites you to change it ..or to press f 1 to go with it anyway ..
so..either is calling you to go to bios and set it ..cause you somehow reset the bios to the factory ..or it is a hard disk notice ..
I f it seam not to find any hard disk in teh system ..try to go to bios by pressing F2 or F10 cause it is a hp after all ..and in there change the settings for the ahci function and let it run ide compatible ..it may be the cause too for not booting up from hard disk ..
In the end I suggest to change bios battery ..cause a flat battery wioll also cause F1 on each boot to confirm the settings and set the date and time ..or just reinstall it cause it may have something on hard disk and caused the lost of data ..
let me know more about this if you can not manage or non of my scenarios does fit to the problem ..
Dec 23, 2011 | HP Presario m2105us Notebook
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
I get F2:E0 F2:E1 and F2:E3 as well as the continuous beeping. Unplugging does not resolve the problem. I can turn on the oven, sometimes, but it goes off by itself. Sometime the controls don't work at...
Kitchen Aid Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line openfrom what this says you could have a bad touch pad,it says to press cancel,if the code comes back after a minute you have a bad touch pad.there's a tech sheet on you machine with all the codes on it,look behind the top console taped to the back.make sure you put this back,if someone comes in to work on your machine and that paper is gone it will be hard to work on it,all machines are different.
Apr 21, 2011 | KitchenAid KGST307 Gas Kitchen Range
My dell 5125 indicates internal hard disk drive not found. it asked me to reseat the drive...than it indicates no bootable devices- i'm strike F1 to retry to boot and F2 for setup utility....nothing...
Try accessing setup utility and verify there if it still recognizes your hard drive, if not then that means your hard drive had crashed. If you have important files on the drive, you can try to recover it by going to a local service provider and have your files recovered, and of course you have to get a new hard drive for your dell.
Sep 13, 2010 | Computers & Internet
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
When I turn the power on the computer beeps twice and I get a message saying that there is no secondary drive and it gives me the options of pressing f1 to start windows or f2 to go to setup.
Press F2 to go to setup. See if there is a listing of drives anywhere. It should say something like "fixed disk 0", "fixed disk 1", or "PATA drive" "SATA drive". Use the arrow keys to select the secondary drive (probably drive 1) and hit enter; change it to "none" or something similar. Then save the settings and reboot. That should take care of that message.
Jun 18, 2010 | Computers & Internet
Pc won't boot
In your system actually the hard disk is not found because of some loose connection; so you just try to remove your hard disk and then start your pc and shutdown it after 1 minute. and then just attach your hard disk properly.
Check all the cable.
Mar 02, 2009 | Dell OptiPlex GX270 PC Desktop
No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
