I have intermittent green lines in equal size boxes across the whole of my computer screen. once it starts i have to close computer down.
  • 57 Answers
You have a bad video card i think. sometimes electronics will still work untill it heats up and then it will crash. this is a chip failure and all you can do is replace the whole card
Posted on Dec 02, 2008
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Blue green red line middle screen
REFIX LCD VGA CABLE NOW CHECK PROBLUM SAME SO LCD IS FAULTY .
Aug 26, 2017 | Acer Computers & Internet
Laptop screen keeps flickering
Changing the refresh rate might help.
Right click on the screen. In the box that comes up select Graphic Properties. In the window that comes up click information. Box that comes up select monitor tab. Will have a list of display sizes and refresh rates that are supported by your monitor. Once you have that information you can make changes.
FYI: Acer says max resolution 1920 X 1080 with 75 HZ refresh rate.
Also if you have a tube light or speaker system close to the monitor then try moving it further away.
Apr 30, 2012 | Acer Computers & Internet
Download my digital picture from SD card into a folder
HI
one way of doing it is
make a new folder on you desktop right click it and rename it then call it what you want it to be
then open that folder go up to the top right hand side of it and click onto the square next to the red x which closes down the folder
this should open the folder in about half a box size
go to the long verticle side of that box click on it and drag to make it about half of the screen size
allowing for another box to be place on the desktop as well
then plug your sd card into laptop slot
if computer reconizes it it should either open it or give you a box with option to view
when open go to the pictures starting from the top left place mouse over the picture
left click holding it down drag it down and across the screen until all pictures are highlighted
then just drag them over to the new folder that you made and renamed
they should then be in the new folder
Feb 26, 2011 | Computers & Internet
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
Relisys vertical bars
Sorry this wont help you much, but may put you out of your misery trying to repair it.
The LCD panel has failed. In particular the driver tabs that connect to the physical panel have failed and there is no way to repair them.
The only soloution is to replace the entire panel, a cost that would be close to if not more then a new TV of the same size.
I would put it on Ebay for parts (powerboard, logic board etc), and use the money towards it's replacement.
Peter
Mar 25, 2010 | Relisys RLT1720 17" LCD Monitor
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
Apr 08, 2009 | Mitsubishi CS-27205 TV
Power
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
57" Toshiba with wavy green/red lines "good overall picture"
Appears to be a convergence problem, the chips are located on large aluminum heat sinks. Check near the 2 or 3, STK IC's for + and - voltage usually 20 to 25vdc. If 1 or both are missing, check microfuses. They should both be close to equal in voltage reading, if not, turn set off after it has been on for 10 minutes, feel the heat sinks at each IC,if one is hotter than the other, replace both IC's or all 3 if it has them. Now check the small low ohmage resisters in and around the STK IC's and you will most likely find a few burnt or discolored and have changed in value, replace these or the new chips installed will self destruct.
Jun 26, 2007 | Toshiba 57H81 57" Rear Projection...
Computers & Internet Logo
David Payne
David Payne
