Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Resetting the indicator light
We have an LG DLP model RU-52SZ51D which just had the lamp replaced under warranty by the technicion. We got the amber indicating light that said it needed replacing. I wasn't home but he told my wife that he needed a special remote to reset the amber indicator but had forgotten to bring one. Is this something I can reset myself? If so, how? Thanks
Hold down on the Enter or OK on the TV and Mute on the remote control for 5-10 seconds. The TV should then ask what you want to do. Perform this with the TV on.
Posted on Jan 31, 2007
LG RU-52SZ51D problem turning on
I have the same problem as Shawn. I'm hoping after about a year this post may pop back up and get a response from someone who could help.
Thanks.
May 12, 2013 | LG RU-52SZ51D 52" Rear Projection...
How do I switch the bulb in a DLP projection TV model RU-52SZ61D
I just replaced the bulb/lamp on my LG RU-52SZ51D TV. It was fairly simple. Basically you have 2 screws that hold on the cover panel on the right side of the TV. Once you take off the cover, you'll then see a metal tray with a handle. That has 3 screws, you can then pull out the tray and see the bulb/lamp. The lamp has 3 more screws that hold the little brackets that hold the lamp in place. Last you have the 2 power wires. One is connected by a screw on the left of the lamp, the other is attached by a nut and a washer on the back of the lamp, where you would usually screw in a normal light. The two wires are just connected to a single plug to the right of the lamp which you can remove, you get the new lamp with the wires already attached. All you have to do is plug it in after you mount it back up. Here is the info on purchasing a lamp, sorry but I am still in the process of learning how to reset the lamp indicator light...
Website:http://www.partstore.com/ProductDeta...ModelID=491016
Zenith Projection TV Lamp
Zenith Part Number: 6912B22002C
LG Electronics Model: RU52SZ51D
Don't miss your favorite programs, keep an extra Zenith TV lamp on hand. NOTE: THIS PART IS MANUFACTURED BY OSRAM. IF THE OLD LAMP WAS MADE BY OSRAM, USE THIS PART.
Price: $ 273.83
Here is how to reset the lamp timer.
lamp reset on lge :to reset lamp timer press and hold ENTER or OK on tv display and MUTE on remote at the same time for 5 to 10 seconds, lamp reset box will pop up you can then reset lamp.
Aug 27, 2011 | LG RU-52SZ51D 52" Rear Projection...
My LG DLP RU-52SZ51D rear projection TV doesnt turn on.
See if Lamp Fan is running it can be defective and if Fan is OK it will be Ballast Board, Call Encompass Parts 1-800-638-3328
Dec 31, 2009 | LG RU-52SZ51D 52" Rear Projection...
Just replaced the bulb on my ru-52sz51d how do i reset the lamp timer
press the menu button on the front panel
while holding button on panel press and hold the menu button on the remote control
service menu will appear and then keep pressing the menu button until you come to lamp hour resetting
press ok on remote
and now lamp hour is reset
Nov 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
I have an LG DLP. that turns off after 15 -30 seconds
If the second light is blinking to orange or red, that is usually the lamp indicator light on an LG DLP tv. That indicates your bulb needs replaced, or something surrounding the bulb has failed (like the cooling fan for the bulb for example) IF you have a spare bulb handy, I'd replace the bulb, keeping in mind if you touch any part of a new bulb with your bare hands, you just cut the life of the bulb by more then half.
Jul 30, 2009 | LG RU-52SZ51D 52" Rear Projection...
Changing lamp on lg dlp
On my unit there's a panel on the lower right hand side, remove the 2 screws with a screw driver. Inside you should see a compartment that is metal and has a thin metal handle. Remove the Black screw on the top left hand side. Then pull the unit out with the handle. Inside the unit holds the bulb, just replace and go through these steps in reverse to place back together.
Aug 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
No picture-lg ru-52sz51d
Hi lovelace Check your power supply module it needs to be replaced.good luck
Apr 25, 2007 | LG RU-52SZ51D 52" Rear Projection...
TV keeps shutting down
Sounds like it may be a bad ballast
Mar 24, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
214 people viewed this question
Steve Allison
Steve Allison
