Question about Ovens
I'm looking for the reference of the fan oven element for Rosieres F142FA 4039343280 oven. Thanks
  • 744 Answers
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
Posted on Jan 30, 2014
You can contact Eurafrican who are the agents. Cape Town: 0215113925. Jhb: 011 8805980
Posted on Oct 05, 2009
  • 57 Answers
I hate the website but you can order the documentation from here
http://www.rosieres.biz/
Posted on Dec 02, 2008
Upper and lower elements in my bosch HBE 632 elec oven work well individually but only the lower element works in dual element mode.
Hi.
If it is a fan assisted oven, and it is the fan oven you are referring to, then I would suspect the fan element to be faulty.
Assuming you are in the U/K, this should be located at the rear of the oven compartment behind a removeable cover.
Alternatively, it is possible that the selector switch could be faulty, but I would check all elements first.
Feb 15, 2011 | Bosch Ovens
Rosieres 4040DB cooker - Problem with oven doors
hi can you please give me a call re this... I have the same problem on my 4040db and I am keen to know if/how you resolved it, many thanks Simon 07787 511443
Jul 07, 2010 | Ovens
Main oven light works fan runs but oven doesn' get warm
May 23, 2010 | AEG U3100-4 Electric Double Oven
Can i replace element on a fan assisted europa solarplus oven
If you are referring to the main fan element, then it is a very easy job to replace it.
You will find it located at the rear of the inner oven compartment behind a removeable cover.
Apr 11, 2010 | Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Neff B1432 oven element and fan not working
If the element has failed again in such a short time , then I would suspect that the fan is the culprit.
If the fan is not working, then the element overheats, and burns itself out.
The fact that the fan spins freely, proves nothing, as the fan can be still faulty.
The only way to prove if the fan is faulty, is to remove the oven from the housing, and remove the rear outer panel of oven,.test with a meter set to ac mains and test the fan motor terminals to see if there is power there when oven is set to heat, disconnect the element first. ,if there is ,and the fan is not running then the motor is faulty..
If there is no voltage there, then problem is elsewhere, and you will have to investigate furher.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1432 Single circotherm plus Electric...
Fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Dacor model W305 blew an element. Replaced it. Won't work.
The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
It is highly unlikely that the fan and element are faulty, you will have to look further.
Thanks, and merry xmas.
Dec 20, 2008 | Ovens
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Thanks.
Dec 15, 2008 | Belling XOU270 / XOU271 Electric Single...
Replacing the element in a diplomat 5706 cooker
Hi.
You will probably have to remove the rear panel of the oven, this is on the outside that I am referring to, and you will see the 2 securing scews for the element, you might have to push the insulation to one side to see the screws.
This should solve your problem.
Please good feedback if this helps.
Thanks.
Nov 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
305 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
