Question about RCA RC5215P DVD Player
Finding lense I've got some good advise about cleaning my lense on my DVD player with cotton swab. I'd like to know where exactly is the lense and how would I do this, and also I'm don't know what the IC is.
  • 624 Answers
If you've already cleaned the player with a good quality commercial DVD cleaning device then you have done just about all that a typical user can do short of taking it apart. I just had a real nice DVD player die last weekend and was surprised to be able to pickup a fairly decent DVD player/recorder for under $80. I also noted that a basic DVD player (also played audio CDs) started at $30. On the one hand the old one cost over $150 a few years ago and I hated to just give up on it, but for $80 I got a new unit that recorded and had one year warranty. Had I taken it to a repair shop it would have cost at least $40 with no guarantee other than 30 or 90 days. Have you considered just tossing the old one and purchasing a new one?
Posted on Feb 02, 2007
    Scholar:
  • 119 Answers
To find the laser remove the cover, with the dvd tray open. now you may have to remove the piece of plastic that covers the dvd when it plays. below that is your laser. the lense itself is about the size of a pencle & clear plastic. cleaniong the laser with a swab is a lot better that relying on those lens cleaning kit you can get. as for the ic i don't know what you mean? good luck.
Posted on Jan 31, 2007
SOURCE:
Getting message - "can't read" & "no disk"
sounds like the laser is out of synk with the encoders inside the player, to fis this you will need to disconnect everything from it, unscrew it and carefully move the lase all the way to the outside of its track, BE CAREFUL NOT TO TOUCH THE LENSE WITH YOUR FINGER, you may also wish to clean the lense while you are in there anyway. To do this dip a cotton swab in Isopropyl alcohol (the kind you use for cuts and scrapes), and roll the tip accross the lense of the laser, just let it air dry. Reassemble the player and it sould be good to go.
Jun 30, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tip
How to clean the lense on your CD or DVD player
If your unit has some time on it it probably has a dirty lense on the laser assembly. This isn't difficult to clean but you must exercise care not to damage any components of the laser assembly.
Unplug the unit. Remove the top cover. If the disc drive has a cover, remove it. You should see the lense, which looks like a fish eye, looking up at you. The lense is mounted on a set of springs and will move around as you clean it. This is normal but do not apply anymore pressure than necessary.
The alcohol will do the work loosening the dirt. Using 200 proof grain alcohol, and commercial grade, lint free, cotton swabs, (available from any electronic parts supplier, here is an example www.mcmelectronic.com ), moisten swab and gently touch the lense while rotating the swab head.
Use a dry swab after the wet one to remove the loosened dirt. Blow dry the assembly with canned air, also available at MCM. Reassemble unit and you should have a working player.
In the unfortunate chance that you still are not reading discs you could have a defective or weak laser assembly. This would have to be replaced with a new unit. I hope this has helped you.
Thank you for using FixYa
hardrocko
on Feb 13, 2010 | Audio Players & Recorders
Dvd's won;'t play
The laser lens may need to be cleaned with rubbing alcohol and cotton swab. Just remove the cover of the player and clean the lens. This usually corrects the problem. If cleaning doesn't help, the laser is defective
Jul 01, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd player is unable to read cd showing NO DISC
You can try resetting the setting to the factory specifications. To do this on your remote push the setup button. Use the up and down arrows to find highlight preferences. Press ok to enter the sub-menu. Once in the sub-menu use the up and down arrows to find default. highlight this and press ok. Then press the setup button to exit. This will restore the factory setting and hopefully the full use of your player. If this fails to restore the operation of you dvd player, you can try using a lens cleaner and see if the dvd compartment needs cleaning. You can do this with a can of compressed air. If you need to clean the dvd lense use a cotton swab and a small amount of isopropyl alcohol.Apply a small amount of the alcohol to the tip of the swab and gently rub it back and forth until the lense looks bright and shines. Use the other end of the swab to dry excess moisture from the lense. Also check the transport and see if it needs to have dust and debris from the tracks or gears removed. Use the same process with cotton swabs a small amounts of alcohol to clean it up. Once clean try playing a dvd. It should work fine. If not you may have another problem with the lense or motor. You can call Phillips customer support at this telephone number. 1-888-744-5477 they will be able to help you with getting service for you dvd player. I hope this information help you with your problem.
Mar 12, 2009 | Philips PET710 Portable DVD Player
Lite-On LVW-1105HC won't record, often fails to read disc.
Judging from product reviews it seems that this is a fairly unreliable unit. About the only thing you can do to possibly improve performance is to clean the laser lense. There are commercially available cleaners for CD/DVD players. The best way to clean the lense is to disassemble the unit and use a cotton swab with alcohol. This may be difficult for someone who doesn't have experience disassembling electronic devices.
Dec 31, 2008 | Lite On LVW-1105HC DVD Recorder
My dvd video player often won't read good discs as being good ans says they are "bad" or no disc when I know the one inside is ok. If I try multiple times it may work. Why and thanks for your...
Your DVD player is about to break completely. The disk is spinning too slow at times. I currently have a similar problem and have not yet determined if the motor is bad or the chip that drives the motor or the main processor chip. There is a slight possiblity that a poor power supply is at fault. Because of the high cost of repair it's probably not worth repair. Oh yes, one other possibility is the lens that reads the DVD may be dirty. You can try to clean it and see if it helps, Use a cotton swab with alcohol (not the kind you drink) and gently wipe the plastic lens the dry it with the dry end of the swab. Look closely to make sure you don't leave any cotton behind. You only need a little alcohol. Don't over due it. Good luck,
nssms
Sep 12, 2008 | GoVideo Televison & Video
DVD Player
There should be a problem in dvd reader the lense or check the dvd and dvd player that run's such kind of DVD's or not if not you must insert the card that supports such typeof DVD's
May 23, 2008 | GoVideo Go Video DVD/VCR Combo
Nothing ever plays
You can try to reset the dvd Player to the factory specification by using the default option in the preference menu. Use the remote control and push the set-up button. Use the up and down arrows to highlight the preference option. Press ok and enter the sub-menu. Use the up and down arrows to highlight the default option and press ok.This will reset the DVD player to the factory specifications. If this does not work for you . Try cleaning the DVD lense with a cotton swab and a small amount of isopropyl alcohol. Put a small amount of alcohol on the tip of swab and rub it back and forth gently across the lense, until it appears bright and shines. Also check the laser transport and see if it need cleaning of the dust and debris that can accumulate in the in the
dvd compartment. Use cotton swabs with small amounts of alcohol to clean the transport rails and gears.Check to make sure the action of the transport is not impeded by any dust or debris. Also check the gears and make sure they are clean and look in good working order. After doing all this take a can of compressed air and blow all the dust and debis from the dvd compartment. Try playing a cd or dvd and see if the palyer is working properly. If not check the spindle and make sure it is snug and working correctly, holding the dvd correctly for the laser to read it. If it feels loose try using a drop of super glue to make it snug again.Try playing a cd or dvd and see if the player works correctly. If not then you probably are having a problem with the laser lense itself or the motor drive. They may have lost the ability to run under specifications due to useage or ageing. For these problems you should call Phillips Customer support at 1-888-744-5477. Give them the modle number of your dvd player and the problem you are having with it not being able to read discs. They will be able to tell you how to have it serviced and repaired. I hope this information helps you with your problem.
Mar 01, 2008 | Philips PET710 Portable DVD Player
Boombox CD player
Hi Could be bad spin motor, but the first thing to try is load the cd and put your ear to the unit and listen for a ticking sound...if there is, then the laser is trying to focus. If not ticking, there is likely a serious problem, and the whole unit should be replaced. If you hear the lense bouncing up and down, then it is likely a dirty lense or bad laser. To clean it, use a cotton swab and wet the end with at least 70% USP rubbing alchohol(99% better). Touch the swab to the lense and a drop should form on the lense, gently move the drop around to loosen any debris, and then use a dry swab and touch it to the lense to absorb the drop. Try the unit, and if it was dirt on the lense, it should work, if not the boombox should probably be replaced. Good Luck!
Sep 27, 2007 | Jeep JXBLK Cassette/CD Boombox
Cd not reading
problem no disc when this is a disc in the player
Jul 08, 2007 | TruTech TT1620 DVD Recorder
RCA RC5215P DVD Player Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
