Question about Brother HL 1440 Laser Printer
My power went out and now my printer won't work!!!?
My power went out and when it cam back on all of the lights on my printer were blinking and I can't get the printer to work. I have a Lexmark Z25.
    Problem Solver:
  • 18 Answers
Contact the company that made the printr and chek out the waranty on the printr
Posted on Jan 05, 2009
2 Suggested Answers
  • 18 Answers
SOURCE: My power went out and
try contacting the company that made the printer and check out the warranty on the printer.
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Two red light are blinking and show general error
Hi. My epson T50 printer is flashing together two orange lights showing general error, have reset ink pad with software but still the same problem. Any ideas would be great. Thanks Jim
Mar 13, 2012 | Epson T50 InkJet Printer
Hp pavilion a1217n tower won't power up...the green light in the back is blinking rapidly....help!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Lexmark z2320 powerlight blinks and printer won`t work
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
May 19, 2009 | Lexmark X2550 All-In-One Printer
Blinking lights and e on start copy
Have you tried re-booting your computer?
Apr 01, 2009 | HP DeskJet F380 All-In-One Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Blinking lights
Hi
Lets try all factory resets, that will resolve this issue.
PARTIAL RESET:-
Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
If it didn't work try next reset.
SEMI_FULL RESET:-
Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.If it didn't work try next reset.
FULL NVM RESET:-
Take out the ink cartridges. Turn the printer OFF. Unplug the power cable from the back of the printer and from the wall outlet. Press # and 9 simultaneously and while holding # and 9 insert the power cable. Then release the button and turn the printer ON.
If you still have the same problem, printer needs to be serviced.
Thanks
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
Printer went dead
cheri g:
You can get a copy of the reference guide here. Or you can get the Windows User Guide from here.
As far as the blinking lights, there is a couple of links to check. If all lights are blinking check here. If only the Power & Resume Lights are blinking check here.
For the power issue, I would check here after you have verified all cables are passing power and that all doors on the printer have been closed.
Hope this helps. Please rememeber to rate this information.
Thanks
Aug 26, 2008 | HP DeskJet 5550 InkJet Printer
Brother HL 1440 Laser Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
