FixYa.com
Tags:
Bosch 700 Watts MUM7010 Concept Series Stand Mixer
Incomplete mixing
posted by riri on Jan 31, 2007
How do I keep things from sticking to the bottom and middle of my bowl? The beaters don't seem to completely clean all the surfaces and I end up with a layer of ingredients stuck on the bottom and middle and they don't properly mix in with the rest of the ingredients.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 15, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This mixer cannot be raised or lowered to adjust. I too have had the same issue with bread baking. Try spraying a light layer of Pam on the plastic bowl before mixing. This may help.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 07, 2007
Not Rated (0)
oscarn
Rank:Wiz Wiz
Rating: 75%, 48 votes
You need to raise the bowl just a little less than the thickness of the layer presently being left behind. Too much and the beaters will touch the bowl .
Can you Help with these Mixers problems?
Mixers
KA mixer repair manual download
Mike, you stated "Here is... Answer This...
Mixers
Broken where the beater turns
I have taken the cover off from... Answer This...
Mixers
flat blade stuck on KA stand...
cannot get blade off!! Answer This...
Mixers
Stuck bowl
The bowl is stuck on my Kitchen... Answer This...
Mixers
Hobart HSM20
how to put the greas to Hobart... Answer This...
Repair Service
Find Mixer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
