Sony KV 1975R sound turns to static after about 30 minutes. Switch off/on sound returns briefly.
  • 934 Answers
A series of caps in the audio circuit are failing and need to be replaced. You'll need an esr meter to determine which of thse are failing and short of that I'd strongly suggest you have a tech repair it. It's not an expensive repair and I'm positive you would be much happier with the outcome.
Bill
Posted on Dec 02, 2008
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
Sony Trinitron KV-1975R TV won't turn... Relay problem ?
O'boy do you have it bad-
normally I would say get a new T.V. but in this case I would surggest you find a very good tv.repair MAN,in your area- where he would clean the inside of your t.v.(I knew 1 who use to do this with a toothbrush),and he should also replace/spray your relay switch which sounds like its on its way out. the old ones are the best ones I have an old b&w tv myself that belong to my graddad still working even do its slowy getting out of date with all the digatil now.but I'll find some use for it - best of luck with the old girl..P.
Aug 07, 2009 | Televison & Video
Blacks out for 1-30 min. then back on. Standby light blinks 4x
I would suspect the circuit board around the HV transformer area to have a crack circuit print. Also look around in the vertical circuit for interment solder connections. But only do these things if you have some knowledge of TV circuit lay out. If you do not feel confident then call a professional. No sense in hurting yourself or damaging the the set worse.
Hope this helps,
Skyassoc
Jun 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sound goes off after 5 minutes
hi there, yes it can be fixed, hitting the unit means that you have a cold solder on the board. the sound is in the amplifier section, check some connection at the speakers and amplifier, a cleanning and a reheat of cold solder to the baord is required. ty
Dec 14, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Aug 17, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sound Problem
There's a possibility that you may be experiencing problems with the audio output IC -IC404 - All serial numbers produced until July 2003 might use one of these defective IC's. So if your set was manufactured before this date, that is probably the culprit. If not, and you have it connected to a cable box that has its own volume control, it could be that its volume is turned down and by turning up the TV's volume too high that you are getting this distortion. Hope that helps.
Jan 20, 2007 | Sony FD Trinitron WEGA KV-20FS100 20" TV
Sony KV-27V55 no picture sound ok
I have a KV-27V55 and when I turn the TV on the picture and sound is good for about 30 minutes and then the picture goes off, but the sound is still on. It will come back on after a while.  What do I do?
Hog_mama
Jan 14, 2007 | Sony KV-27V55 27" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-20FS120
It's normal for new sets, especially Sonys to do that due to some sort of gas build-up in the new tube. My set still gets a high-pitched buzz after power on and lasts for a minute or two before silencing. If the hissing continues when the TV is turned off return it to the shop ASAP. It could be a problem with the power supply, something getting ready to blow up. Good luck
May 30, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
