Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker and water dispenser not working
I recently added a water line to my ice maker and water dispenser. I know there is water going into the frig. and into the filter, but I get no water or ice. I did this after having my frig for 2yrs without a water line.
Any suggestions what could be the problem?
    Sergeant:
    Champion:
  • 251 Answers
Well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Posted on Dec 04, 2008
Samsung rs257 ice maker not working. We already reset ice maker and checked water line to ice maker. We also used dryer to defrost bearing on ice maker. Still not working.
Hi!
The manual provides a number of reasons why the ice maker doesn't work:
Ice is not dispensed
Did you stop the ice making function?
Is there any ice in the ice storage unit?
Is the water line connected and the shut-off valve
open?
Is the freezer temperature too warm?
(Set the temperature lower)
Did you wait for 12 hours after installation of the
water supply line before making ice?
I'm adding a link to the manual:
http://manualsbrain.com/en/manuals/948215/?page=29
Jul 21, 2017 | Samsung Refrigerators
Door dispenser not working
Is the ice maker working properly? There is a water filter in the refrigerator through which both the ice maker and water dispenser are supplied and over time it will slow down the flow and eventually block. Have you changed it recently? Often, ice cubes will get smaller as it blocks and the ice maker will also quit.
Also, have you checked the water supply line that goes to the ice maker and water dispenser? It should be a small diameter copper or plastic line that connects to the back of the refrigerator.
Ed
Jan 08, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
How to make the ice maker work
Problems with Ice Maker/Water Dispenser
If you are not getting ice, make sure the water valve is open and the ice shutoff switch or arm is not in the "Off"
position. Inspect the ice ejector arm for blockage and remove any trapped ice with a plastic spoon. If you recently
emptied the ice container, remember that it takes your refrigerator up to 24 hours to produce ice.
Low water pressure is the major cause of problems with the water/ice door dispenser. Low water pressure can cause
inadequate water flow and small or hollow ice cubes. Check the water line for kinks that may interfere with water
flow and make sure the water valve is open. A dirty water filter can color the water and ice cubes, impede water
flow or cause water to have an off taste so remove, clean and replace it.
If water is leaking from the door dispenser, make sure the water glass remains under the spout until the water
shuts off completely. If you recently changed the water filter, air that was left in the line may cause water to
spurt from the dispenser. To flush the water line, let water run from the dispenser for approximately three minutes
or until you draw out 1.5 gallons of water. Try to find a container that will fit under the dispenser spout so you
do not have to start and stop to empty the container.
Have a nice day my friend : )
Sep 04, 2011 | Kenmore Side by Side Refrigerator
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
194 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
