Question about Shuttle Computers & Internet
Shuttle X PC - HD + Power LEDs briefly illuminate, no boot.
Last night I shut down the machine as usual.  Went to start it again via the power button on the front today.  All that happens is the Power (blue) and HD Activity (amber) LEDs illuminate briefly (about .25 sec).  Nothing else happens at all -- no fan, no HD spinup - it's completely 'dead' apart from those LEDs blinking on once.
I've done the usual: re-seated the AGP card and RAM, removed and reinserted the CMOS battery, attempted power-on without any external or internal (non-vital) peripherals connected.  Still no luck.
Any ideas what to try next?
Thanks, Chris
  • chris442 Dec 02, 2008
    Just to add...
    The green LED on the motherboard itself is illuminated (which I presume is a good sign).  The front power and HDD LEDs will flash only on the first press of the power button.   Subsequent presses get no response at all.  The LED flash only happens on the first power button press after unplugging/replugging AC power.
  • chris442 Dec 09, 2008
    Yep - it was indeed the PSU.
    I took out the stock PSU then took a standard ATX supply and ran its power cables in through the back of the Shuttle case. It fired up fine.
    Of course, now I've got a power supply sat behind the Shuttle that's about 1/2 the size of the PC itself, but at least it's working :)
    Unfortunately the Shuttle's quite an old model and the PSU seems to have been discontinued. I'll have a hunt around to try to find one.
    Scholar:
  • 68 Answers
It sounds like you have a bad power supply. It will store up a very small amount of energy (enough to run some LED lights) but not enough to power up the system. That's where I would look. If that is not the problem, then I would look to the capacitors on your motherboard. Good Luck!
Posted on Dec 08, 2008
  • James Swafford Dec 09, 2008
    Glad I could help... Tell me more about the Shuttle and the power supply (pictures?) and I would be glad to help you look around!
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
Hi my daughter used the mac last night same as usual. When i started it up this morning i only have screen saver plus mouse pointing device showing!!! Normal shutdown procedure was followed. thanks in...
I'd guess that it went into sleep mode rather than shutdown. Sometimes the screensaver can only be woken up by tapping the space bar..
If that doesn't do it, hold the power button down for 10 secs and this will force-shut the machine, then boot up as normal.
Regards
Jul 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HP Pavilion dv6225us won't boot (power not the issue)
Check http://www.fixya.com/support/t3440299-presario_f500_laptop_problem
Nov 16, 2009 | HP Pavilion dv6225us Entertainment -...
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the...
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Nov 13, 2009 | Toshiba Satellite A75-S209 Notebook
Screen not responding
can you hear any boot sounds?
(fan noise, harddisk rattling)
do the LEDs work (battery and charger , Hdd, CD/DVD-ROM-drive,WLAN)?
this would indicate it still boots up, but screen might be broke.
u lucky?
- remove battery pack! retry booting
if not, hook it up to another external monitor
(use vga-jack in the back of it)
reboot, wait for signal
- check if the the fan is jammed
(due to sand???)
this might cause overheat problem -
use compressed air to blow/clean the fan inlet
still no luck? it simply may be broke...
Aug 04, 2009 | Computers & Internet
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
HP nx7300 no boot
I guess your battery needs to be flash.
Apr 10, 2009 | HP Compaq nx7300 Notebook
Dell Dimension 5150 starts up on its own!!
Check the power cable for some defect. It may have been twisted and the wires inside broken. Try using an alternate power cable and see how it goes.
Sep 01, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
1,361 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
