Question about LG Flatron Ez T910BU 19" CRT Monitor
LG Flatron T910BU
I CHECK MY MONITOR HAS NO RASTER AND I FOUND THE TRANSISTOR J6820L WAS SHORT BUT I DON'T HAVE SOME SPECK OR DATA OR SOMETHING LIKE THAT OR COMPLEMENT FOR THIS TRANSISTOR, PLEASE GIVE ME THIS, THANK'S FOR YOUR ATTENTION.
What problem monitor not display color
Posted on Aug 04, 2008
LG Flatron L1515S 15" LCD Monitor Problems & Solutions
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | LG Flatron L1515S 15" LCD Monitor
Lg flatron l1730 no power on screen green led not on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 09, 2010 | LG Flatron L1750S 17" LCD Monitor
LG FLATRON E700SH problem wid it is that .its led is flickering dimmly but screen is black out ..? buta sometime after 20m 45 minutes the monitors starts working .but some time it doesnt.??????????
The picture board on your monitor is malfunctioning, since the power led or button is on, but the screen is black out, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | LG Flatron Ez T910BU 19" CRT Monitor
My Lg Flatron switched off
  • that is a problem of smps
  • check the fuse inside the smps
  • check the component which blows the fuse e.g.diodes transistor
  • if faulty replace it
Apr 15, 2010 | LG Flatron L1510S 15" LCD Monitor
Monitor display problem
FLATRON E700S (EB770G-NA)_(CA-109)_(EB770G).pdf search for this file in google and download it for free and this could help ur problem solve
Jun 03, 2009 | LG Studioworks 700S 17" CRT Monitor
LG FLATRON E700SH is not displaying RED color
there is ovbiously a fault with the monitor and w ould be best if you bought a new up to date monitor then if any faults consist with that one you could just take it back
Dec 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Open back cover of lg E700SH
there is a lock system to this monitor put crt front portion on table take a smallest screwdriver insert it into the narrow gap and pull the cover upperside it will open there are two gaps anyone you can try
Nov 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
T910BU
The plug was cut off from this monitor and I need the wiring diagram for it, can you help me?
Nov 28, 2007 | LG Flatron Ez T910BU 19" CRT Monitor
LG Flatron Ez T910BU 19" CRT Monitor Logo
340 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
