Question about Sony KDS55A2000 55" HDTV
Can you tell me HOW to replace the bulb on the sony kds60a2000?
  • 934 Answers
Kcasey,
It's covered in the owner's manual which you can obtain here: http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DOCS
Just type in your model number and it will display a pdf which you can navigate to lamp replacement...
Bill
Posted on Dec 02, 2008
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
I have a Sony WEGA, Model #KDS60A2000. The screen has a green tint to it & also states that the rear projection lamp is nearing end of life. After research & reviewing class action lawsuits, replacing...
YOU WILL NEED TO REPLACE THE OPTICAL BLOCK; I don't think you're going to get much help from Sony at this time. The cost to make the repairs are not cost effective on a unit of this age.
Go shopping for LED or LCD TV
Jul 22, 2014 | Televison & Video
Optical Block needs replacing
unfortunately the optical blockissue kills any resale value except for the chassis boards value for used boards. Parting it out will be your best bet as alot of people may be needing the boards.
Feb 27, 2013 | Sony KDS-60A2000 60" HDTV
Very front screen is scratche on my sony sxrd kds60a2000. what is the part number and cost of replacement
Contact a service center for replacement. Seriously, the 60inch panel has to be removed in order to replace the front film which is no easy feat due to its size. Since it is already scratched though, you might try using a polishing kit to see if the scratches can be buffed out. Will never be back to original unless replaced, but might be worthwhile depending on scratch severity. Check with service center or local electronics retailer for the polish kit. Some rental places may be able to buff the display for you as well, but don't expect a guarantee of results. Worth the try though.
Aug 21, 2011 | Sony KDS-60A2000 60" HDTV
Our Sony TV Model KDS60A2000 screen is black with only Video 4 on screen, has green lite showing the TV is on, however, does not have picture. Could it be the lamp?
It could be but if it is the lamp you wont be able to see anything on the screen, the screen would be black. You sould check the lamp if it looks old and burned out you may want to replace it. If you do replace it make sure not to touch the glass lens on the new lamp.
Jan 03, 2011 | Sony KDS-60A2000 60" HDTV
Sony KDS60A2000. I replaced the lamp but the message came up and said I did not. I did not know about the reset timer in the set up. Now the tv will not turn on.....just 3 red blinking lights where it says...
According to the manual (pg 53) : "If the lamp is not securely reattached, the self-diagnostic function may be triggered and the POWER LED blinks three times."
Jun 24, 2010 | Sony KDS-60A2000 60" HDTV
Kds60a2000 tv won't switch on red light blinks 6 times if i turn tv on the green light blinks then it goes back to red light this is the power light
Have you tried putting in a new bulb for the screen. Our TV did that and it was the bulb needed replacing. Ours is on the side towards the back. You can order it online, its cheaper than paying a repair man to do it. The first time we did it cost us 500 dollars and then the second time it happened I ordered off ebay for only 170 dollars. Big difference Huh ;) Good Luck
Nov 12, 2009 | Sony KDS-60A2000 60" HDTV
Sony blinks 6 times wont turn on...is it worth fixing
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Jun 26, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony sxrd bulb doesnt last 9blinks
IF SET HAS ERROR 9 THEN THE S1 and S2 board ARE PROBABLY THE REASON. DID YOU USE ORIGINAL SONY LAMPS ? GENERIC LAMPS (ESPECIALLY IN SONY) DON'T LAST. AND IS THE SET IN A CABINET ? I HAVE ALSO SEEN PROBLEMS WITH THE FANS GETTING DUSTY AND THE VENTS ON THE SIDE OF THE SET FILLED WITH DUST.
DON..
Jan 29, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDS55A2000 55" HDTV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
