Question about Lexmark Office Equipment & Supplies
Getting a 290.01 error on lexmark x644e - Lexmark Office Equipment & Supplies
  • 13 Answers
This is fairly common issue. Usually this is just a problem with the pick rollers position on the enganging tab.
So open top cover where the feed rollers are. Follow the shaft of the pick rollers to the front of printer. You should see a CLAER tab somewhere. It is supposed to sit on TOP of the WHITE engaging tab but more than likely is under it. Take something small & flat like a key or small flat head screw driver. PUSH the WHITE tab down which will aloow the CLEAR tab of the pick rollers to move up into the correct position. Close the cover. You should NOT have to power cycle the unit.
The cause for this is usually someone either over stacking paper or leaving a staple on the paper.
Posted on Feb 04, 2009
I was getting this on a 646e, and this fix solved it right away. THANKS A MILLION. saved us from outsourcing a tech to come look at it, when all it was was the little tab. Thanks!
Posted on Mar 30, 2009
  • Lexmark Master
  • 19,396 Answers
290.01 is scanner jam.
This error guide is for x642, but the error codes are the same.
X642e MFP
This happens when the scanner fails to pull a sheet from
the ADF.
When you get 290.01 check for jammed original in the scanner. Remove the jammed paper, then reset the machine unplugging power cord for ten minutes.
Posted on Dec 02, 2008
Lexmarx x644e dark copy
Check the transfer roller, cartridge
Apr 14, 2014 | Lexmark X644e All-In-One Laser Printer
Check toner cartridge
The error 200.16 on a Lexmark X644E indicates that the main drive motor is not working due to high mechanical load due to paper jam or bind. The recommended actions are:
- Make sure paper path is clear.
- Check motor to system card connections.
- Replace transport motor.
I suggest you contact our Technical Support Hotline on 1-800-539-6275.
Jul 26, 2012 | Lexmark X644e Laser Printer
Lexmar X644E enciende carga software hasta el 50% y da : 900.80 Rip Software
Please click on the link below to see instructions on how to go about the procedure.
http://bit.ly/qxvmNN
For further assistance, please call Lexmark Technical Support.
Jun 09, 2011 | Lexmark X642e All-In-One Laser Printer
No Nvram printer en impresora lexmark x644e
2 options:
1 - Turn off the machine and unplug the power cord leave it unplugged for 10 minutes turn it back on.
"probably not going to resolve it" - T
2- you will need to replace the system board / formatter. this is the board where you plug in the usb/ phone line/ network cable.
"This should definitely take care of it based on my experience with this machine."
Oct 19, 2010 | Lexmark X644e Laser Printer
953.99 NVRAM Failure - how do I clear (if it's possible) this?
Contact Lexmark support and get the current firmware for the printer. This may or may not fix the problem, but the next option is a bad engine card and the firmware upgrade should be free.
Oct 10, 2010 | Lexmark X644e Laser Printer
What is 945 error on MFP X646??
This is a hardware issue and the only resolution is to replace the scanner control card. I suggest you contact Lexmark technical support or your authorized service provider for assistance.
Jul 21, 2010 | Lexmark X644e Laser Printer
Lexmark Printer x644e, Geting Blue Screen of Death
allen_logan
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Feb 02, 2010 | Lexmark X644e All-In-One Laser Printer
Lexmark x644e LCD Display Inverted(Upside Down). Restored factory defaults but that did not help.
You will likely need to replaced the LCD panel
Lexmark p/n: 40x0494
You can order it here at www.fastprinters.com
40x0494
Dec 08, 2008 | Lexmark X644e All-In-One Laser Printer
Epson C87 Plus Printer
Hi Alice
After all this time I presume you have solved your problem If not, post a new comment to this effect, and we will take it up. Otherwise we will assume it's solved.
Jan 13, 2008 | Lexmark X644e All-In-One Laser Printer
first thing i would do is update firmware
http://support.lexmark.com/static/229-1-0-530.html
Dec 18, 2007 | Lexmark X644e All-In-One Laser Printer
1,536 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
