Question about Lexmark Computers & Internet
Lexmark x1270 - have had this printer since february and it has worked fine up until now. When I turn the printer on the power light just flashes green (blinks). I deleted it from my printers folder and when I turned it on again my computer showed a message saying INS Res DLL not loaded? Any help that you have would be most appreciated. thankyou so much :)
  • 1,061 Answers
Posted on Dec 02, 2008
  • Lexmark Master
  • 19,396 Answers
Now that you deleted the printer you need to reinstall the driver either from disk or from the download.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printerdoes not work on Vista, if you do not find any driver download for Vista on your model page, that means your model is not Vista compatible.
My lexmark x1270 has power,but will not print from the pc
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Oct 06, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X1270 on/off light keeps flashing. was working correctly, until i changed the ink cartridges, then i couldn't get the computer to communicate with printer to tel the printer that new/old ink....
One card is not recognized. Try to remove, clean contacts on the cartridge and the printer and then put them back.
Check if you use the correct cartridges and you put in place.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 10, 2011 | Lexmark X1270 All-In-One InkJet Printer
Unable to un-install old driver from my computer.
try turning off the printer, if it still won't uninstall, boot the computer in safemode (hold down f8 when you turn it on untill you see the boot menu) and try to uninstall it then. just in case, the latest version of your driver is available here:
Aug 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printing and coping problem has some of those options
Jul 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270 scanner problem
Its the motor. If its not yet a year old call lexmark to have it replaced under waranty
Jul 01, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer.
You might want to download the Vista drivers from Lexmark Canada website.
It works perfectly fine for me.
- JNY Consultants Inc. Toronto, Canada.
Apr 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer power button blinking won't print
I had the same issue with my Lexmark X1290, I solved it by opening up the device, so the ink cartridges should pop, they didn't so I pressed the power button to switch it off, and then switched it back on (with the device open!) and all the paper flowed out, the flashing stopped and it could print again. Good Luck!
Feb 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Hello, i got a problem with my lexmark x1270 printer
If you run Vista OS, the printer will print but Lexmark All-In-One centre will not work.
I have sent you a mail.
Lexmark appologized for the inconvenience and promised to solve that issue during February.
Jan 22, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can`t get my Lexmark X1270 to download on my pc.
When the power button is flashing, try unplugging and replugging the printer. If it still keeps flashing try removing and reinstalling the cartridges. Make sure nothing is obstructing movement of the cartridges inside the printer.
If nothing helps you may need to buy a new printer. Be sure to check first if Windows 98 is supported, because lots of new printers don't support old versions of Windows.
Sep 25, 2007 | Lexmark X1270 All-In-One InkJet Printer
Computers & Internet Logo
210 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
