Question about Dell OPTIPLEX GX150 HEAT SINK & COOLING FANP/N 50044D A02
When i go to turnon the power it tell me to press f1 help
Hi well i need some help how can i set all the bios well my brother just mix up all the bios , can you please tell me how can i go from top tp bottom thank tou dell optiplex gx150 ...
Look in the BIOS for the setting that says reset factory defaults or reset system defaults. This will reset theBIOS to the factory defaults. Resolved.
Posted on Dec 09, 2008
I have a GE Profile Water Heater Model #SE40M12AA01.
I recommend safety changes to prevent ruptured water heater and assorted leaks.
135 degree hot water.
Maybe replace TP valve if it is dripping.
Drip pan under water heater with 3/4" drain line to outside.
Expansion tank on incoming cold water line to absorb pressure build-up, and prolong life of tank and plumbing.
Here's why:
1) Yes you can have scalding hot water.
2) I recommend 135 degrees since that will burn the evil right out of ya. And generally kill clothes washing bacteria.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) 150 is dangerous and can seriously burn skin in 1.5 seconds. Not safe around children and elderly.
4) Temperature settings on electric water heater are approximate, since thermostats are calibrated approximately, and read temperature through tank wall.
5) Also if you want to increase amount of hot water for high-consumption household, then setting tank temperature upward is one solution since more cold water is mixed with hot, so amount of hot inside tank goes further.
6) High temperature can cause TP valve to release water.
TP valve is pressure-temperature safety valve. Do NOT cap off.
Rating should be 125 psi and 180 degrees ... but all things water heater are approximate, and TP valves need replacement now and then.
It is not recommended by water heater manufactures to use 150 psi TP valve when water heater came with 125 psi. Rating shows in small print on end of TP. New TP valves sold at local hardware. Let tank cool before installing new one.
7) Higher temperature and high pressure can rupture tank.
Pressure over 80 psi shortens life of water heaters and plumbing fixtures. Put BTG100 pressure gauge on water heater drain valve to check pressure.
8) You need a drip pan with 3/4" drain line to outdoors, or to drain vent line, to prevent flood caused by ruptured water heater.
Turn water heater off when going on vacation.
Inspect water heater each 6 months.
Drip pan available at local home center or hardware:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#drip
9) Heated water expands and puts pressure on tank and pipes.
Water does not compress... so when water gets hotter it expands against tank wall and against pipes.
Especially in closed system (check valve present) when system is without expansion tank.
Expansion tank is installed on incoming cold water line.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#expansion
Oct 31, 2012 | Water Heaters
I have the Brother 2600i sewing machine and am having problems with the blind hem stitch being too loose on the top & bottom. I currently have it on the 2 setting for stitch length, 4 for stitch width...
I would put my tension at 3, length at 2 and 3-5 for width. Make sure that your machine is actually on the blind hem stitch pattern, If this does not work, call Brother at 1-877-276-8437 and have them tell you where to take it, if they cannot guide you through it. I hope that you are under warranty, or that you can return it, if there is a mechanical problem.
Dec 28, 2010 | Brother XL-2600I
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
Hi, My sewing mechine is brother lx-3125 and my problem is getting loose stitch on both sides of fabric when i set stitch is 10 and tension 4-6..and also i am getting loose stitch on other no also like 9...
Most likely your machine is not threaded right, read your manual closely and double check yourself. Rethread your machine, no mixed thread use same weight, color does not matter but weight does. With your presser foot down, your top thread should be had to pull, with it up it should pull freely. Make sure your bobbin is wound evenly, and on a fresh bobbin. Then put in a new needle. Now, if the machine is still acting up, it may be your timing. You can call Brother at 1-877-276-8437 customer support. if you need a manual, go to www.brother-usa.com. I am answering this for free just to try to help you. Good luck
Oct 07, 2010 | Brother XL-5500 Mechanical Sewing Machine
Sewing machine Brother xl-5301
When the bottom stitches are loopy it is the top tension which is wrong. I suspect that it is not threaded correctly for it to be this bad. If you have a tension dial make sure that the thread is properly between the disk. Try the top tension on 4-that is an "average" normal setting. Gradually turn it up as needed. A good way to test tension is to use 2 contrasting colours-red and white are good. You will see at a glance where the problem lies and how well you are correcting it with adjustments. You should barely see a trace of the top colour coming through. Rethread the machine top and bottom with 2 colours-set dial to no 4 and go from there.
Jun 13, 2009 | Brother XL-2600
The mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 12, 2009 | KitchenAid KP2671 Professional 6 Series...
Instructions on refilling cartridge for brother LC41CL cartridge
Do mix the ink with some glycerol to prevent clogging!
2ml glycerol (85%-glycerin alc. from drugstore) with 10ml of ink for C/Y/M and shake well (mix) before use. Mix 1,5 ml glycerol with 20ml BK ink.
Simply drill a hole into the brandname (O of brother) on top of the cart. Refill with 12ml for C/Y/M and about 21ml for bk.
You can leave the hole open.
Next time when cart is empty simply open scanner and refill without taking the cart out! ;-)
DO MIX THE INK WITH GLYCEROL!!!
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
I need help
Go into your bios, with whatever button it tells you to push. In there, look for anything that resembles Startup... Theres alot of menus I know, just use the arrow key to look through.... Once u see the start up menu, make sure the Harddisk is 1st (or in some bios, it has to be at the top of the list). To do this, there is a legend at the bottom (or top) of the screen that tells you which each computer key does for these menus. Use this, then, once its 1st (or at the top) of the other options, (other options being cd/dvd, usb, floppy, etc, varies computer to computer), push the save and close key (which again, is on the legend). Tell me if this works please>.<
Jan 08, 2008 | Computers & Internet
Window XP Media Center Edition won't boot up if Brother MFC-440CN is connected.
I would go first with Brother's support suggestion. You can always go back to the original BIOS setting.
Jul 27, 2007 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
116 people viewed this question
Alun Cox
