Question about Sylvania 6319CE 19 in. TV/VCR Combo
Sound I've only had my tv for four years, recently the sound started fading in and out. Now the voices sound really hollow and any music associated with a show only comes through in interrupted short fragments. Is this fixable or should I go out and purchase a new tv?
  • 38 Answers
Check and replace the audio IC output. If it is transistorise audio output check if it is open or leaky or even check if theres an open resistor 1 watt at the audio board area. good luck!
Posted on Feb 12, 2007
    Scholar:
  • 168 Answers
Its still fixable. change the audio output ic(integrated circuit). but if you are not inclined with this job, have it check with a qualified service technician. good luck!
Posted on Feb 03, 2007
How to delete voice on change od sound volume
Delete voice and change the audio sound.
Audio Point allows you to change the volume of a portion of the clip. For example, to fade out or out the music track.
To add an audio point, double-click on the audio line where the fade should start and where it should end. Then move one of the points up or down to create an audio feed effect. Are you know free GPS device update here: http://garmin-updates.net/sat-nav/
Oct 16, 2018 | GPS
The sound on all the movies on our tv is soft voice and loud music. How can I set the volume to be the same for both?
Some TV's have sound settings to empathies voice. If the TV has a centre speaker you can increase the sound output on that. That will make voices louder.
However many people do complain about loud music drowning out voices on TV. The problem is that movies were meant to be seen in cinemas and TV sound systems don't match up to that. If you can't find a solution consider a surround sound system as this will correct the sound problems on movies.
Nov 21, 2017 | The Audio Players & Recorders
Humming sound
This type of sound can be generated by the back-light inverter board.
Jun 15, 2013 | Sony BRAVIA KDL-52XBR4 LCD TV
Hitachi 51F710E has no sound
The audio portion of the main board is failing. You can get a replacement here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jun 07, 2017 | Hitachi 51F710 Rear Projection Television
We have a 150. When we add a MP3 it sounds great until you add voices into a mic then it fades out. What could be causing this?
Turn the VIP level all the way down for the microphones you are using over the Mp3 music. If the VIP levels are up, the music will fade out so you can make an announcement.
Jun 10, 2011 | Fender Passport Deluxe 500watt Sound...
My vizio tv is practically brand new as of christmas, when a movie or even tv is on the voices are very soft and the music or background noises are EXTREMELY loud, so I am always turning the volume up and...
I had this problem with my previous TV (Syntax by Olevia, an off brand). It only happened to me on certain channels, and for certain shows. What is happening is the TV station is broadcasting the audio in Dolby 5.1 format. For some stupid reason, the TV is playing the background speakers (effects) instead of the speaking parts. You get a little bleed-over of the voices into the back speakers, so voices are there but really quiet. Unfortunately my TV didn't have any surround sound options to fix this.
See if your TV has a surround sound option. Otherwise, you will need to connect the TV sound output to a surround sound system that can properly decode the audio channels.
Feb 06, 2011 | Televison & Video
Kp 61HS30 TV Had the tv since 2002. been a great tv. Just recently it started making a noise when you turn it on. Noise fades away after about 10 seconds. Noise kind of sounds like a dvd player trying...
If you locate the audio board, check for dried up electrolytic capacitors and dry joints around the output IC itself.
That should fix your fault.
Nov 27, 2010 | Sony KP-61HS30 TV
Sreeching loud sound
How does it sound using external speakers? What is your signal source...broadcast, cable, satellite? Is the static continuous or does it fade in and out with voices (lips moving) and / or sound effects / music?
Aug 26, 2009 | Digimate DGL2700 27 in. LCD Television
Sound
i think the Tv is Normal working. No need to replace the TV. the problem only in your audio processing circuits. Audio driving unit or Audio power amplifier IC might be faulty. You can replace this IC and get the real sound back. To do that contact authorised service personnel. all the best
Dec 22, 2007 | Philips 32PT6441/37 32" TV
Sylvania 6319CE 19 in. TV/VCR Combo Logo
56 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
