I have a pioneer anh p9r head unit for my car but do not have the plug to connect it anyone know what plug i need
  • 57 Answers
It is probably here
http://www.installer.com/wires/
Posted on Dec 02, 2008
I need directions to connect my mp3 player to my pioneer deh 3700mp car stereo
Assuming that you're not trying to connect an iPod or iPhone, you will need an additional adapter. For your particular unit, that will be a Pioneer CDRB10 Auxiliary input adapter for P-Bus receivers (approximately $40). You'll also need a stereo mini plug to RCA adapter (about $15 for a good one of around 6 ft). You'll plug this adapter into the headphone jack of your MP3 player and the RCA ends of the adapter into the RCA ends of the Pioneer CDRB10. Then for the hard part, you'll need to plug the other end of the Pioneer CDRB10 to the rear of your stereo head unit. That will mean pulling the unit out and doing some fishing so that the wires are hidden and leading to a location where you can functionally attach and detach your MP3 player.
Oct 20, 2013 | Pioneer Audio Players & Recorders
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
No Power for Pioneer Avic-N2 after installation
yes, you need to connect the brain in order to power the main unit.
Oct 21, 2009 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
Remove basic unit from the housing in the dash
you need two little flat pieces of metal that slide down each side of the unit to release the clips these come with the radios usually if you know anyone that has purchased a pioneer head unit you should be able to borrow them to do it. if not go talk to any install shop they have them laying around and will sometimes part with them. if you cannot get ahold of them you will have to remove your dash and pull the bolts out and remove the entire chassis to get at the back then reinstall it. you did not say which car you have so i cannot help with the dash removal.
May 15, 2009 | Pioneer DEH-P2500XM CD Player
Connection to IPOD
There are many ways to do so. Each of which is progressively more expensive.
All of these plug into the Ip bus plug in the rear of the unit.
Most of these can be found on Ebay or Amazon
1: An IP bus to RCA plug then you need a RCA to 3.5mm plug wire. (note this is a lower quality) $10-$30
2: An ip bus to Ipod connect plug. (Better sound quality, charges Ipod, does not allow Ipod control from the Head unit, only from the Ipod) around $15-$30
3: An ip bus to Ipod Connectivity unit (same quality as #2 but allows for Ipod control from Head unit)
$100+
Feb 01, 2009 | Pioneer DEH-P3500 CD Player
No sound
Try removing the "face off" panel and ou will find a small near the bottom to left of centre. insert thin screwdriver to press reset button inside. thismay do the job..Mike.
Aug 21, 2007 | Pioneer ANH-P9R CD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Wiring Installation - Satellite Radio
The wire that runs along with the P-bus cable connects to constant power; the other wire needs to be grounded.
Jan 08, 2007 | Pioneer GEX-P910XM Satellite Radio...
 Grubhead
Grubhead
