Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100 - no power
I recently moved, and when I tried to startup my computer after the move I got no power. The power light does not light up at all. I do have power to the monitor, shows the amber light.
On the motherboard, the green LED lights up. But when I press and hold the power button I get nothing. No sounds, no lights, nothing.
Please help me with what the problem may be. I checked all connections and nothing seems to have come apart. I did not unplug and replug everything, only some of the connections. But everything seemed to be firmly in place.
  • 1 more comment
  • cayenne987 Dec 02, 2008
    that's the box the the power cord goes into right? I believe my father has an extra one with a slightly lower wattage. I dont have much on the computer, and the only thing i ever plug in for power is my iPon nano...so it shouldnt matter that I have the lower wattage?? I'm at work now and dont remember the difference in watts, but i dont think it was much. I'll try it tonight and let you know tomorrow if it works....or i guess tonight if it works. ha.
  • Anonymous Dec 05, 2008
    Same problem here
  • bags59 Dec 22, 2008
    after You replace the power supply what do You do next after the system trys to boot and message on screen reads " noboot device available"
    President:
  • 2,110 Answers
It seems that your SMPS power supply may be having some fault...try to replace it...
Posted on Dec 02, 2008
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Want power up
Any lights at all? try swapping a printer power cord or another power cable on it. Does the fan on power supply move? CPU fan moving?
Need more info.
Jul 08, 2009 | Dell Dimension E510 PC Desktop
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dimension 5100 wont power up
check powersupply, boot into recovery console and run chkdsk /r if able, and yes you can mirror the drive and recover data. may also be able to do repair install.
Dec 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Power problem on Dell Dimension 5100
plz check the ram and powersupply unit and try to reset the bios
Sep 02, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No powerup
is ram pushed in good cpu setted well video cards pshued in tight power pushed in good main one plus 12 v atx power ? 4 pin
Jan 20, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
123 people viewed this question
Alun Cox
