I have a Maytag, front loading, electric dryer Model #LDE9314ACE. When we close the door the unit does nothing. I figured it may be the door switch, which I later found out to be Maytag P/N 305754. If you just push the switch straight in, the dryer will not turn on at all. However, I discovered that if you lightly pull the door switch to the right while pressing it, the dryer turns on every time. I don't want to damage anything and would like to find out how do you remove that switch in order to change it???
SOURCE: Flashing "touchup" and dryer won't start
What I did was unplug it for 1 min., plug it back in. Push the "off" button once, then push the off button again and hold it for 10 seconds. This is supposed to reset the computer. It worked for me.
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
SOURCE: Maytag dryer [electric] MED9600 lights up but won't start
The control panel seem to have the problem.
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
