Benq laptop power unit 'short'?
Thanks for your reply but I have tried it without the battery and it's still the same. I note that when the power lead is plugged in the green light goes out then blinks but no lights come on on the computer.
  • 4,806 Answers
The fact that the LED light on the power supply tells me that its receiving power, look where the AC adapter goes and check the pin to see if it is loose, this sounds like feedback from the computer causing the power supply light to dim or go out
let me know how you get on
Posted on Dec 02, 2008
Mother bord bios reset
To Fix, Try to open up your laptop then find cmos battery which you remove for 15 mins and while removed short contacts on motherboard where battery was which should restore default bios.
[Dont forget if shorting battery contacts avoid static electricity.]
Then replace battery in correct orientation and reassemble.
Oct 24, 2013 | BenQ Joybook 5000 Notebook
I had to replace the motherboard on my HP DV5 1140us laptop. As soon as I replaced it, I tried to power it up. It wouldnt power on, but by where the power adapter goes, it's a constant blinking light...
Try operating the unit without the battery.
If it works, the battery is probably shorted, and may have caused the subsequent failure of your previous motherboard.
If that doesn't help, post a reply here and I'll see what else might be the issue.
Mar 18, 2011 | HP Pavilion dv5-1000us Notebook PC
Benq joybook 7000 not turning on. thanks
I would try another power supply. Also try it without the mains just on battery power to see if it comes on if not your system board is faulty
Feb 23, 2010 | Computers & Internet
Battery dead in my HP laptop will not start with power cord
take out the battery and try to start the computer with it plugged in using the power lead. If this owkrs without the battery being in then the power lead is fine. If this doesnt work it could possibly be the power lead or the power supply inside the laptop. Does the power lead converter (the black box half way down the lead) get warm when plugged in for a while, if so the power supply is probably the fault
Jan 20, 2010 | Computers & Internet
British power lead for American laptop
Hi and thanks for replying. Basically any 'figure of eight' lead will do the trick, but I can dig one out for you if you would like?
Feb 18, 2009 | Dell Inspiron 1525 Notebook
Benq S41 power suppl ''short"?
thats what i suggested earlier, the AC adapter in the laptop has blown, thats what causing the feedback/overload. you can fix the problem yourself but it is a big job!!!
If you need the problem resolving straight away, then take it to be repaired, under warranty if its still covered by it!!
Sorry for the misunderstanding
Kind regards
Dec 02, 2008 | Computers & Internet
Internal power unit 'short'.
Ok its not the power supply, it the battery in the laptop which is defective. Remove the laptops battery and power on using AC power only, the PC should now boot and your problem will be solved (apart from the battery)
post back to let me know how you get on
Kind regards and please don't forget rate us
Dec 02, 2008 | BenQ T2370 Notebook
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Benq joybook 5000
do one think change the battery and try to connect it in other laptop
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
