Question about Kenmore 72602 Gas Dryer
Pilot light out on GE Gas Dryer
We think it has an electronic ignition (dryer is less than 5 yrs old).
  • 1 more comment
  • angela428 Dec 02, 2008
    Thanks! It seems that it does have electronic ignition - do you have any idea how to re-ignite the dryer? Or maybe I need to replace the part..?
  • angela428 Dec 03, 2008
    Actually the manual doesn't say anything - it has troubleshooting tips for electric lol. The model is PWSR483GB1WW. It is about 5 yrs old. Thanks so much!!
  • Alan Matzke
    Alan Matzke May 11, 2010
    What model is the dryer? If you have a manual for this unit , in the manual I believe it would tell you some where if it is electronic ignition. let me know what you find out . biigg53566
  • 177 Answers
SOURCE: Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Posted on Aug 22, 2008
appldoctom
  • 311 Answers
SOURCE: Gas dryer doesn't heat up
,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow if two clicks and no glow [its your ignitor] but you can use a volt meter and make sure 110 volts at ignitor if voltage replace ignitor with new.if not two clicks then its going to be your thermal fuse its in the same area as the burner Therese two kinds[only one in each dryer tho],both white having two wires and small, one looks like a missile the other a fling saucer.ither kind you can put the two wires going to it to gether ,isolate them with tape and try heating.if heats replace.now if fuse you need to check for any blockage,inyou house or dryer.over heating can cause the fuse to open if i can be of more help you can email thru fixya God bless ,tom
Posted on Jan 10, 2009
  • 51 Answers
SOURCE: how do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Posted on Mar 13, 2009
mastatech
  • 478 Answers
SOURCE: gas dryer maytag MDG 7600 AWW Heats - then shuts off
Check the flame sensor mounted to fire tube, its a rectagle with a glass window, also the coil can be replaced on gas valve if they are weak,
You definitly want to check the exhaust vent and vacume.
704-819-6557 for tech help and parts.
Posted on Mar 14, 2009
  • 72 Answers
SOURCE: Pilot does not light onWhirlpool gas dryer
change the glow plug
Posted on Apr 15, 2009
How to light the Pilot light for GE Dryer DDG7980
Your dryer does not have a pilot. It has a "igniter". Here is a link to the part if it is not glowing to ignite the gas.
Jul 28, 2011 | GE Dryers
My dryer wont get hot . think the pilot is out . .. how do i relight the pilot
send the model number,you can't light the pilot anymore,they are electronic ignition now,is it gas or electric?find the model number around the opening where you put the clothes into dryer
May 08, 2010 | Kenmore Dryers
How do you light the pilot
Hello. There is no pilot light. Instead, these dryers rely on an electronic ignition. Joe
May 01, 2010 | GE DBSR453GBWW Gas Dryer
General question on pilot light
Gas dryers have electronic ignition. No pilot to worry about. Dry away. Careful, don't lose those socks now. Have a good day.
Jun 30, 2009 | GE DBXR463GB Gas Dryer
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
How do I light the ignite pilot light
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Gas pilot not lit in dryer.
It has an electronic igniter,Just make sure the gas is turned on the the dryer(at the valve located behind it)and make sure the power cord is plugged in.
Please rate this a fixya
Feb 03, 2009 | GE DBXR463GB Gas Dryer
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Kenmore 72602 Gas Dryer Logo
456 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
