SOURCE: I need to download panasonic pv-gs19 driver.
Did you insalled to your computer the software CD comes with the camera? In case of a positive answer- Check if the software support your OS.
SOURCE: how to transfer video from camcorder to pc?
yeah get a capture card and a y plug in for the camera, 2 RCA ends and one head phone jack to plug into the front of the camera
SOURCE: Using panasonic PV - GS250 with mac
I believe what you are doing is trying to download both video AND photos using the same port. They are two different functions. One connection is under the video door, and the other is in one of the other hidden ports of your camera. Give that a shot. Also, make sure the dial is set on playback (the red videocamera icon) when connecting it to your computer when you transfer the video. This is not the same when transferring photos (which come from the SD card you have, not the tape), and the wheel has to be set to PC.
SOURCE: LCD broken Panasonic PV-Gs 320
Hey, all.
I also have this problem, but have a little more to add:
Here is a website that carries the lcd screen: http://www.pasc.panasonic.com/Epartr/PartsList.asp
I think that its the following part number:
L5BDDYH00022
LCD DISPLAY (MONITOR)
87.56
$87.56 sucks, but it could be worse. Problem is now, I'm not sure how to replace it without taking the entire camera apart.
Let me know if someone does this successfully.
Thanks!
EAL
I have found out that GS65 does not have the pass through capability.
