Question about Exercise & Fitness
I have a Reebok Fusion Treadmill, an Oil Can Icon has appeared
In the display to the right of the calories catagory, an Oil Can icon haas appeared. Can you explain the problem or what I should do. I use the treadmill almost daily and lubricate the deck and belt as per the instruction manual.
  • 7hug Jan 04, 2009
    hey, how do u lubricate the fusion treadmill? i lost my user guide :S
  • Anonymous Mar 19, 2009
    same
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John Please follow procedure below:
1. Keep power on and remove the safety key
2. Press and hold incline down and speed down, at the same time insert the safety key
3. You can release the “Down” buttons. (you will now hear a beep)
4. Press Speed up
6. Press stop. You will now hear a beep and the icon will disappear
Posted on May 18, 2009
JUST BOUGHT SECONDHAND REEBOK T3.1 TREADMILL AND IT DID NOT COME WITH OWNERS MANUAL / INSTRUCTION BOOK !!! DOES ANYONE KNOW WHERE I COULD GET HOLD OF ONE. .......THANKS
Posted on Dec 05, 2013
There is an oil can symbol on my Reebok T 3.1 can I removed it? ( certain models only).
Posted on Dec 08, 2010
My Nordictrack E7 SV elliptical is not powering on when plugged into the wall outlet. I tried putting batteries in and it still won't power on. Is there a fuse or something that may have blown?
there would be a circuit barker on the treadmill. check whether it is in off position .
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 08, 2017 | NordicTrack Exercise & Fitness
Thermomix tm5 error message C152
If you wish to get some details about treadmill error codes ; visit the site linked here. Pull up older posts.
Jan 07, 2017 | Exercise & Fitness
How many calories does a 4.3 mile run burn?
500 to 900 calories depending on your weight and the amount of time it took to run it. If you were running hard and consistent then you would burn more calories.
Oct 12, 2013 | Exercise & Fitness
Schwinn srb 1700 will not read the speed or RPMs and the unit turns off after 5 minutes by itself. I was thinking of replacing the sensor but I can not find the part online. Any help would be great.
please see the video and lube the rollers bearing front+back too
2) Run the software calibration for easy diagnostic with sensor speed.and fix it.
Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
God bless you
Oct 01, 2013 | Exercise & Fitness
Woodway treadmill parts
Ernesto I don't have a manual. Is this sensor near the front of the machine or the back ? Is it on a board or ?
Thanks,
Andrew
Jun 07, 2013 | Exercise & Fitness
Key pad not working
Most likely the control panel and its accompanying control circuit board is defective.
Jan 22, 2013 | Proform - Zt3 Treadmill
Exercise & Fitness Logo
3,276 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
