Question about HP Officejet 4315v All-In-One InkJet Printer
Bad paper jam
I have used a 4x6 photo paper for Christmas cards. One of the papers got jammed really bad. I tried using the 20-30 papers with manual feed button, but the big paper came through great, but the small paper still is jammed. PLEASE HELP!!!
    Novelist:
  • 88 Answers
Repeat paper jam
there likely a jam in there your not seeing or feeling
Jan 26, 2013 | HiTi P510L Digital Photo Printer w/Breeze...
Printer jam
If your paper is jammed inside, open the printer and gently pull the paper back out to fix the problem.
May 23, 2008 | Canon PIXMA MP780 All-In-One InkJet...
C5180 sounds like printing then jams
try aligning the heads, and cleaning ink cartridges
Nov 18, 2012 | HP Photosmart C5180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
Willl not feed 4X6 photo paper it jams up and
try feeding the paper in one sheet at a time.
Sep 14, 2009 | HP Office Equipment & Supplies
Paper Jam
No still jammed will contact the shop I purchased it from or ask the IT people I deal with at work if they have solution. Thanks
Dec 01, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper Jam HP 1350 All-In-One
The back of the HP psc 1350 DOES open! I got a 4x6 photo paper stuck too. After finding no help in the HP software manual, I accidently noticed that if you look closely at the back that grey area that looks like it should come off does! If you look closely you will see an arrow to the left of the gray panel. You can push right and pull toward you at the same time and the panel comes off where you can easily take out the stuck photo paper.
Nov 06, 2008 | HP PSC 1350 All-In-One Thermal Printer
Paper jam
It's pretty rare to not be able to manually clear a paper jam. Occasionally, after you clear a jam, some paper gets stuck in the mechanism where your fingers can't reach. In that case, part of the printer mechanism needs to be taken apart to get to the jam. Like I said, it's pretty rare, but when it happens, your only option is to take the printer to a certified printer repair shop or back to the place where you bought it to get it worked on. Unless you know what you're doing, I wouldn't recommend using tools inside the printer yourself. You run the risk of damaging the mechanism and making your current problem worse.
The HP web site does publish a couple of solutions. Have a look at the information on the following two links and see if there's anything you may not have tried yet:
Clearing a Paper Jam
Clearing a Carriage Jam
Post back whether or not either of these links worked out for you. Good luck.
Oct 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
83 people viewed this question
Seeker5211
Seeker5211
