Question about Minolta Office Equipment & Supplies
I have copier minolta CF3102 when I made copies the border of paper is dirty Can you help me?
  • vito1709 Dec 02, 2008
    THank you,
    the dirty is less but I would like to disappear this dirty in the border of paper.
    I have to clean the 4 toner because this is color
    copier machine Minolta CF3102.
    What Do I do?
    I looked for the independent technician because I can't to pay monthly payment (contract)
    We are in Tampa
    Thank you for your help
  • vito1709 Dec 03, 2008
    Yesterday I was cleaning my color copier but today in the morning my machine is not working the display this code C-3C50.
    My Color copier machine is Minolta Dialta CF3102
    Please hel me!
    Scholar:
  • 134 Answers
Auto Panel Reset
The machine automatically resets all modes and functions to their default settings if one minute has passed without the machine performing any opens.
If the magnetic card is removed from the optional data controller, the machine assumes that the user has changed and automatically resets all modes and functions to their default settings.
When the touch panel is reset, all settings that have not been stored, such as the number of copies, return to their default settings.
The conditions for all modes and functions automatically returning to their default settings can be specified using the “Auto Panel Reset” function on the User’s Choice: 1 screen.
Energy Saver Mode
If the copier is not used for 15 minutes, it automatically enters Energy Saver mode.
When the copier enters Energy Saver mode, the indicator on the [Start] key remains lit in green and the touch panel goes off. The copier conserves energy and waits to receive a job.
If the copier is not used for 30 minutes, it automatically enters Sleep mode.
TI P
The length of time after the last operation until the copier enters Energy Saver mode can be specified using the “Energy Saver” function on the User’s Choice: I screen.
To recover from Energy Saver mode
I Press the [Start] key. (The Energy Saver mode can also be canceled by pressing any key on the operation panel or by touching the touch panel.)
2 The touch panel comes on again, and then after the copier has finished warming up, it is ready to begin printing (after about 30 seconds at normal room temperature (20 °C))
Turning the Copier On and Off
To turn the copier on
-, Set the power switch to “I”.
When the copier is turned on, the indicator on the [Start] key lights up in orange. A screen indicating that the machine is starting up appears.
After a few seconds, the message “Now warming-up. Ready to scan.” appears on the touch panel. When the indicator on the [Start] key lights up in green, a job can be queued.
To turn the copier off
I Touch [Job Log] to check that no jobs are queued.
2 If any copies or printouts remain in the output tray, remove them.
3 Set the power switch to “0”.
The following are cleared.
• Settings that are not programmed, such as the number of copies
• Data scanned using the “Scan to Memory” function
• Jobs queued to be printed
• Jobs saved with the “Memory Recall” function
Stored zoom ratios, programmed Copy mode settings, Utility mode settings and User Box settings are not erased.
Note
Do not turn off the copier while it is making copies or printing, otherwise a paper mis feed may occur.
Do not turn off the copier while it is scanning or sending or receiving data, otherwise all scanned data or transmission data will be deleted. Do not turn off the copier while a queued job or stored data is waiting to be printed, otherwise the jobs will be deleted.
Default Settings
The settings selected when the copier is turned on (when the power switch is set to “I”) are called the default settings.
The default settings serve as a reference for all settings that are to be made.
• Number of copies: 1
• Color: Auto Color
• Finishing: Non-Sort
• Zoom: 1.000 (Full Size)
• Paper: Auto Paper
• Mixed Orig Detection: Off
• Copy 1 Set: Off
• Original: Single-sided
• Copy: Single-sided
• Original Direction: None specified
• Margin: None
• Thick Original: Off
• Photo/Density: Text&Photo
• Background density: Standard
• Density: Standard
• Glossy Mode: Off
• Auxiliary functions: All off
• Color Image Adjust: Standard
• Creation: All off
Tip
The language of the displays in the touch panel can be changed using the “Language Selected” function on the Admin. Mode: Admin. set screen.
The default settings that the copier resets all functions to can be specified using the Utility mode.
i hope it helps!!!
Posted on Dec 03, 2008
    Genius:
  • 1,239 Answers
Hi you will have to check the Minolta web tech support team for this one
Posted on Dec 02, 2008
  • 734 Answers
Hi,Your problem is occurs due to the glass (mirror) of your copier, needs to be clean by thinner or replaced by new one that will fix your problem.
Thanks for using FixYa.
  • futureloginn
    futureloginn Dec 10, 2008
    Sergeant:
  • 217 Answers
It can happen if the toner is leaked inside the machine. also it can happen if the toner drum is faulty and needs replacement. it could also happen if the waste tonner collector side of the toner cartridge is full it leaks if gets full and needs to be made empty by disassembling the toner cartridge. the waste side gets full only if the using side of the toner gets empty or low. or the final option replace the toner if the printer is totally cleaned.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Basically sounds like a major cleaning of the inside. As this would involve dis-assembly, a step by step procedure as explained in a service manual would be your best bet. Alternately of course would be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Genius:
  • 1,011 Answers
Dear sir/madam,
This is problem of dust in toner. Clean the toner it will cleared off. Click this link for how to clean the toner.
thanks
good luck
Don't forget to rate the solution
    Genius:
  • 1,550 Answers
Clean the paper path inside the printer using a soft, dry cloth.
  • Minolta Master
  • 19,396 Answers
Teh inside of the printer/copier must be cleaned, see :Clean your laser printer safely with these tips
or call a technician to do a cleanup.
    Genius:
  • 1,142 Answers
All you need to do is clean the inside of the printer after removing the toner as it is leaking.
    Top Expert:
  • Minolta Master
  • 77,499 Answers
Clean the inside of the copier, toner dust gets everywhere after awhile and causes this, also check the cartridge, it may have a problem, rebuilt ones tend to do this.
Cf3102 Stapler issue
There is a sticker on the finsher normally located on the side of the finisher againist the copier. if network then check properties of the printer when you select printer on the computer.
Mar 18, 2010 | Konica Minolta Office Equipment & Supplies
I had a paper jam last night on my Minolta CF3102 copier, and after extracting the paper that was jammed I tried closing the end access panel and it would not fully close on the right hand side. There...
Sir,
Check both latching hooks sometime one mite break!, also check the cover above the fuser (Hot part). Also check that the paper dust remover has not come out of place. This has two blue arrows on it. Is your duplexer cover on correctly, this cover is and option attached to the right side of the machine.
Feb 18, 2010 | Minolta Office Equipment & Supplies
When copying a book there are black inks in border
If you copy something that is smaller than the paper you are printing on, this will happen, especially with a book. The copier will copy everything within the sensor range, and if there are no area to copy, it will scan in the blank space. With a book, the cover will be elevated, and the sensor will pick up the "black" border you are talking about and copy it to the paper.
Feb 02, 2010 | Samsung SCX-4300 Monochrome Laser...
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
Misfeed
Your running double sided copies? Have you open the duplex section? What type pape using
Mar 28, 2009 | Konica Minolta Office Equipment & Supplies
I have a Minolta cf3102 color copier. I pulled out 2 paper jams in fusing unit. Now it displays paper misfeed in duplex unit. I have checked all the paper transport way but I can not see any obstacle....
on the duplex unit is located on wright side .open the first outer door looks like 2 door in one .if you do not see any paper look for black actuator .in the center make sure it's not hanging up.
good lock
Mar 28, 2009 | Konica Minolta DiALTA Di200 Copier
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
MINOLTA CF3102 PRINTER
This code is related to fusing pressure, which could mean fusing unit malfunction.
Put paper clip through a hole under LED cleaning pads inside the front door to reset.
Caution!!! Not recommend for the end user to reset fusing related codes since it could result in a fire.
Mar 07, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
67 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
