Question about Altec Lansing VS2221 Computer Speakers
No sound from headphones connected to speaker
There is a headphone jack on the right speaker, but with my headphones plugged in, I continue to hear sound through the speakers and none from the headphones.
  • 64 Answers
I may be too simple of an answer but that would happen if the headphones weren't plugged all the way in. If there is a bend in the connector and it's hitting the speaker they may not be plugged in all the way.
Posted on Mar 28, 2007
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
My dell inspiron N5010 's internal speaker is not functioning..but i can hear through my head phones
The problem is in the earphone jack, when you plug headphones into the jack it dis-connects the internal speaker. Since you can hear the sound through the head gear, it indicates the jack is defective and needs to be replaced, or it needs a good flushing of electronic contact cleaner, attach the supplied straw and aim it in the jack and spray, next take the headphone jack and push it in and out quickly, repeat the process three or four times, If this fails the laptop will need to be dis-assembled for continued repair.
Jan 21, 2011 | Dell Inspiron 1525 Laptop
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Marshall MG50 DFX amp line out/headphones not working
Contrary to what's posted above, the Marshall MG series does not pass the speaker power output through the headphone jack, and inserting the headphones into the jack does not disable the speaker. The headphone amp is a separate circuit and it's input is taken before the master volume. So Jan's post is exactly right. Turn off the master volume and turn up all the other gain/volumes as high as they will go. The other issue is that the headphone jack's output does not drive low efficiency headphones well, so you need some headphones similar to Sony's MDR-V700s to hear it well. Earbuds just don't cut it.
Mar 07, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Low sound in headphone
I would say it is because the unit does not have a built in amplifier. The speakers are powered PC speakers of studio monitors I am guessing. Try plugging the headphones into the headphone jack of the speakers if they have a headphone jack or try a set of powered headphones out of the Edirol and see if it helps.
That should remedy the problem.
Dec 27, 2008 | Edirol UA-4FX External Sound System
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
Dec 22, 2008 | Creative Labs Sound Blaster Live! 5.1...
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Altec Lansing VS2221 Computer Speakers Logo
205 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
MegaByteMe
MegaByteMe
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
