Question about Kenmore Elite 45986 Front Load Washer
F - error code
How do I remove the bottom panel under the door. Seems pretty tight andno pulling has loosened it. I got a F- error no number and I unpluggedthe machine and replugged it. Error gone but door is locked and I can'tget my clothes out. Complained about it not spinning at end of cycle.Repair came out said nothing wrong and first time using it it did thesame thing but now have this error code. I am not a happy camper. Anyhelp would be greatly appreciated
  • Anonymous Apr 27, 2009
    My He3 beeps and flashes "F" no number and does this near the end of every load. What do I do?
  • 5,911 Answers
I apologize for not getting back to you sooner. There are three screws under the bottom edge of the panel under the door. Once the screws are removed, the panel should slide down, then off. HINT: Prop the front feet of the washer up with a block of wood to make access much easier. Two person lift may be required as the machine is heavy. There is a manual release that you can use the open the door if it will not open. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now...when you unplugged the machine, how long did you leave it unplugged? It is recommended by the manufacturer that you unplug the machine for at LEAST 30 minutes to reset the Central Control Unit (CCU). This is the main computer for the washer. Often this is all that is required to fix momentary glitches with the computer.
Normally error codes are associated with a number or letter combination. It makes it difficult to determine what error is occuring without it. Does the washer have any other symptoms that may be related to your problem? I have several links under the "Tips and Tricks" section of my profile that you can refer to for assistance. I listed some of the more common error codes associated with the Kenmore Elite series. Although the error codes between the HE3, 4 and 5 may differ, the symptoms and cure are the same. You may come across some useful advice that can lead you in the right direction. If your washer does display an error code, let me know.
I hope you can find this information helpful to you. Let me know if you still require assistance.
Posted on Dec 02, 2008
ERROR CODE F, then flash dl
F/dL - Door Lock Error
Condition: A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error. Check or repair the following:
- Door Lock Mechanism broken or removed from the Door
- Check Door Lock/Switch Assembly
- Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
- Door Lock/Switch Assembly Failure
Here is a way to gain access to your washer if the door is locked shut:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement. You can also try to reset the CCU by unplugging the washer for at least 30 minutes.
I hope this helps (remember to rating and leave a testimonial comment about this free answer) Thank you for using Fixya..
Oct 13, 2011 | Washing Machines
Door will not open
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE4T Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2009 | Kenmore Washing Machines
Kenmore HE 3T. Door won't open.
Tip Courtesy JSRock
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 17, 2009 | Kenmore Elite 45986 Front Load Washer
IZ 161S door removal Zanussi washing machine
May 27, 2009 | Washing Machines
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
May 26, 2009 | Kenmore Washing Machines
Lcd showing dle error..machine stops
Door Lock Error.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" "DLE" error codes, these are usually indications of a failed door latch assembly and will require replacement.
May 07, 2009 | Washing Machines
Need to no how to unlock washer cause i can't use it the door is locked. NEED A MANUAL.
May 03, 2009 | Washing Machines
Door on w/mach will not open
Jan 15, 2009 | Washing Machines
Washing Machine Problem
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
287 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
