Question about JVC HD56FH96 56" Television
Full screen for DVD viewing?
Hello, Let me begin by indicating that I do know about the aspect button on my remote and have tried it. The problem is I still have "letter-box" form on the TV when watching particular DVDs. (X-men3 for example) Is there a way to get the full screen for ALL my DVDs or are there some DVDs where it is impossible to fill out the screen? Thanks! -IT
    Problem Solver:
  • 12 Answers
I believe it's impossible as the DVD Manufacturer sets the aspect of the DVD regardless. hope this helps.
Posted on Feb 03, 2007
The picture from the dvd is cut off at the top, bottom, and sides. only analog channels are found so zoom buttons on remote can't help. what to do? dvd player works fine on a different tv. this is a R
Check with an other known disc; have recording in aspect ration 4:3. If that disc show full screen picture, the recording to the present one; you're viewing has wide screen recording. Electro help
Nov 30, 2014 | RCA Televison & Video
Trying to watch a foreign film with subtitles (DVD). The subtitles are getting cut off at the bottom of the screen. TV is on full screen format (not Zoom). We tried moving the picture up the screen, but...
First, try the "Aspect Ratio" button on the remote. If none of the settings remedy the problem, try accessing the menu of the DVD player to ensure that it is set to 16:9 aspect output.
Let me know if neither of these help.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
Has Maxent TV, model # P420142x3; The picture is smaller than the full screen. Wants to know how to get it to go to full screen.
Hi:
Check your remote of a button labeled (Format, Aspect Ratio, Screen size etc, you may have the tv in 4:3 viewing mode. If you are on a cable box and using its remote check for same named buttons.
Mar 10, 2011 | Televison & Video
I purchased a DVD that states: Widescreen Format (Aspect Ratio 1.85.1) I'm unable to get 'widescreen/letterbox'. The movie shows up full screen or a 'stretched' view. All other movies I've...
On the DVD recorder remote: press function menu button: enter setup screen - scroll down to connection - TV aspect - select either 16:9 / 4:3 Letterbox / 4:3 Pan&scan. If you are using an older TV which is not a widescreen, set the aspect to '4:3 Letterbox'.
You should now be able to view your DVD movies from this machine through a 4:3 standard TV in letterbox format. (some DVDs do not allow pan&scan so letterbox or widescreen is recommended). Very rare that a DVD title is not compatible with 4:3 TVs. I assume your deck is set to output 16:9 aspect by default.
I find this is the cheapest and easiest solution and can save lots of dollars in service call-outs. You can always reset the unit back to shipping condition later if you need to, or in the rare case of digital channels disappearing from your tuner memory.
Jan 09, 2011 | Panasonic DMR-EZ485VK DVD Recorder/VCR
After viewing a DVD, and resuming to TV, screen is reduced. How can I get it back to full. It is a Sharp Aquos 2007 model.
Press the button on theTV remote labeled aspect, pic size, ratio or zoom untill desired picture size is achieved.
Dec 26, 2010 | Sharp Televison & Video
Philips 42PFL7862D how do i get rid of the black lines at top and bottom of screen when watching a dvd
Hello; There are many types of DVD players. Few can play videos in full HD mode. The only thing you can try is to change to aspect ratio or display mode on your TV, using the Philips remote. You may not be able to view in any other way. These will all be in the menu on the Philips TV remote control. As painful as it may be, you must fully read the Philips owner's manual. You can also try calling their technical support, if the even have it. I hope this helps! John
Dec 15, 2010 | Philips Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
My picture seems oversized so when viewing it you cant see everything.
What source are you using? Cable Box? Cable tuner? DVD? Computer?
Most of the time your TV's remote will have a button that says "Aspect" or "View Mode" or "Zoom" they can stretch zoom and distort the screen and cause this.
If it is a DVD or Set Top Box you may have to go into the menu or set-up screen and change the aspect ratio to that of your TV.
Let me know if that helps, any more details would be great.
Thanks!
Jan 20, 2010 | Element Electronics FLX-3211B 32 in. LCD...
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
Aspect Function Not Working
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made. For example: A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected. Some Dish Network boxes have Size buttons on their remotes and also in their main menu. It's difficult to determine the repair without knowing the types of the peripherals. Hope this helps.
Sep 09, 2007 | Panasonic PT-52LCX65 44" HDTV
JVC HD56FH96 56" Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
