Dell Laptop Inspiron 1525
My laptop connects to the internet via wi-fi. It shows as connected but it won't brng up an internet page or let me use the internet! Recently installed Windows XP over the Vista it came with if that may be a problem
    New Friend:
  • 50 Answers
You need to update your drivers to be compadible with Vista OS is your problem once you do this you should be ok
Posted on Dec 04, 2008
My internet access through my ethernet cable keeps crashing.I have a dell inspiron 570 and have changed the ethernet cable,power cable,home hub.I can connect ok via wi-fi to my laptop but my desktop does...
Either that or the ethernet chip on the motherboard is failing - you will need to disable this one from the BIOS and install a simple PCI LAN card in its place
Aug 26, 2011 | Dell Inspiron 570 Desktop PC (I5707163PBK)
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
Whether dell inspiron 1525 is wi fi enable?
Yes it is WiFi enabled. You use the slider button on the side of the laptop to switch it on. You can also try use the key combination of Fn+F2 to switch it on.
Dec 11, 2010 | Dell Inspiron 1525 Laptop
I reinstalled my hardrive in my dell inspirion 1525 laptop, i put in the operating disc, it loaded windows xp but i dont have any sound nor do i hve internet and i have a wireless network already set up in...
you will have to hook up an ethernet cable between your laptop and router to download those files, and you should look and check to make sure all other files and software is installed. If anything else is missing, download them at the same time as well. then disconnect from the ethernet cable, install all drivers and software, reboot, and then see if it is working. Also, make sure the switch is turned on for your wi-fi on the laptop. Almost all dell inspiron laptops have a switch or button to turn the wi-fi- on.
Dec 08, 2010 | Dell Inspiron 1525 Laptop
Hi. i want to check if my dell laptop inspiron
The WI-Fi LED is a sign that its Enabled or ON. The LED light on the side of the switch is called the Wi-Fi Catcher.The light operates as follows:
Flashing blue:
Searching for networks
Solid blue: Strong network found
Solid yellow: Weak network found
Off: No signal found
Please comment if the information has been helpful. Thank you and regards.
Jun 22, 2010 | Dell Inspiron 1525 Laptop
Unstable wi-fi connection to D-link DIR-825
check the connectivity again by assigning static IP Address to your DELL.. if problem occurs, clean install the drivers and dell Wifi software to your laptop.. Virus problem also results in this type of problem..
Jun 17, 2010 | D-Link DIR-825 Wireless QuadBand Router
How do i set up this comp. to show wireless connections
Install wi fi network adapter driver.
Turn on wi fi switch it is on laptop you can find it easily.
Then you can see your wi fi network in my network places.
Jul 31, 2009 | Dell Inspiron 2200 Notebook
Wireless Internet wont work unless I plug in a wire
QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
Apr 21, 2009 | Dell Inspiron 1525 Laptop
My laptop has Wi FI My mobile also has wifi can
No. Laptop and Mobiles are passive WiFi receivers. You will need a WiFi router which when connected to internet will create a WiFi zone around it. You can no connect your laptop and mobile to this router.
Feb 26, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
