Question about IBM Infoprint 1572 Laser Printer
IBM infoprint 1572 ink spots
Never had a problem with this machine, after 1st 5000 copies on new cartridge it now has "sprinkles" of ink along left hand margin. Not alot, but not making clean copies
preachw996
  • 1179 Answers
SOURCE: I need to download a driver for an IBM InfoPrint 1572 I bought.
IBM wesite under the support section should have drivers available for sownload. Hope this helps.
Posted on Dec 23, 2008
crayzeetrayn
  • 837 Answers
SOURCE: I a pdf inst. Man. for a IBM InfoPrint 1572 I bought.
This should do it
Posted on Dec 26, 2008
  • 32 Answers
SOURCE: how do i rest maintenance
You need to enter the config menu, by turning off the printer. Hold the middle button and right arrow and power the printer up. Continue to hold the two buttons until you see Performing self test. Then you should see config menu. Scroll to Reset Maintenance count and select it. When it returns to the previous menu, you can restart the printer and the error should be cleared.
Posted on Jul 24, 2009
  • 18 Answers
SOURCE: My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Posted on Apr 05, 2010
Infoprint 1572 code 923.01
The 923.01 error indicated an over temperature state in the fuser assembly caused by a failure in a part called a thermister. You will need to replace the fuser to clear the error. This is a user replaceable part, you only need a Phillips screwdriver to replace the fuser assembly. The part number you need is 39V2600 and they are available from places like amazon.com or Buy.com
I hope this helps, if so please rate my solution.
BuddyMc
May 06, 2011 | IBM Infoprint 1572 Laser Printer
IBM INFOPRINT SAYS IT IS READY BUT WHEN SENT A PRINT JOB DOES NOTHING
hmf..insturctions or send it back and get another one have the ricept (sorry im italian) sned it back
Jan 02, 2011 | IBM Infoprint 1572 Laser Printer
Pages sticking to fuserwhen leading ege has wide
Replace the fuser, its overheating and that would cause the pages to stick the way they have been when trying to print pages of lots of black solid ink.
Apr 19, 2010 | IBM Infoprint 1572 Laser Printer
Feb 08, 2010 | IBM Infoprint 1552 Laser Printer
The copies come out with black spots and toner on the paper.
Black spots on the document usually is caused by either a leaking toner cartridge. A PC drum that is at end of life. Or as simple as spots on the document glass.
Don
Jan 05, 2010 | IBM Infoprint 1120 Laser Printer
How do i rest maintenance codes on ibm infoprint 1572?
Dec 19, 2008 | IBM Infoprint 1572 Laser Printer
IBM Infoprint 1572 Laser Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
