Question about Belkin F8E825 USB Mini Wireless Optical Mouse
Mouse only works for a few seconds and then stops.
The mouse starts at initial hook up but them stops soon after ward. This is a new problem...the mouse has been working for the last few weeks without issue
Have you changed the batteries recently? Wireless mice seem to eat batteries faster. I have a Dell wireless mouse. It will work fine for months and then nothing. That's when I know to change out the batteries. If your batteries are fresh, make sure they are seated in their slots securely.
Posted on Dec 02, 2008
Mouse works for a few minutes then stops working
This has worked for others:
First, power off the mouse, then push on the green-lit button on the transmitter that you plug into your USB. (It doesn't feel too much like a button but you will see that it starts flashing.) Hold it down for about 15 seconds. Then power on your mouse and you will see that it should start working.
Aug 24, 2011 | NexxTech NWOMMI Mouse
I have a GE 99908 Optical Mouse. All of a sudden today, it has stopped working periodically. I have to let it sit for a few seconds and then it starts again. I'm not sure what's going on.
Chances are, the batteries in the mouse are weak. If putting in new batteries does not fix the problem, there may be another device nearby that's causing interference.
Jun 10, 2011 | GE Wireless Optical Mouse
Installed new IRock sp7000 USB 800dpi mouse and it would not work.Updated driver. Pointer worked for a minute and no more, the scroll and the page up and down work OK but no pointer. Any Ideas. Vista OS
Hook up a second mouse.Uninstall the device completely after disconnecting. Reboot twice.
With the second mouse still installed, run the software to install the IRock, only using the new driver if possible. Leave the other mouse hooked up and reboot. It should work from there.
Sep 04, 2009 | i-rocks SP-7000 (SP7000SL) Mouse
Microsoft wireless mouse 700 works, slows, then stops
Seems like new batteries did the trick. Should start simple.
But I am not totally convinced. I will keep an eye on it.
Feb 17, 2009 | Microsoft Wireless Optical Mouse
Mouse stops to soon.
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 05, 2008 | GE Wireless Optical Mouse
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Microsoft Optical 1.1A Wheel Mouse Optical - USB, PS/2 (D66-00034)
Hi again,
Appreciate the direct "Ask Me" and the repeat use of FixYa.
Interesting concern, should be pretty straightforward. Anyways, pls try to:
  • update/re-install the driver from Microsoft Download page;
  • alternately, disable the "Allow the computer to turn off..." in the Power Management tab of the USB Root Hub Properties in your Device Manager.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you again for using FixYa.
Oct 10, 2008 | Microsoft Wireless Optical Mouse
Belkin F8E825 USB Mini Wireless Optical Mouse Logo
939 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
