Question about Dell Dimension E310 PC Desktop
When I push the power button, the power light stays amber.
The PC does not boot up; there is nothing coming up on the screen.
Does your computers power supply kick on or the fan. If not at all there is two tabs on the motherboard. They are small and blue located at the bottom left and just to the right of the first one. they should be connecting a set of pins together on the motherboard take the left one completely off and leave the right one in the same spot. Try the computer again it should kick on. If not replace pin to the left 2 pins instead of the right for a computer reset. Then hit your power button. wait 3 minutes then take the pin back off and put into the normal position. Computer should kick on and run properly.
Posted on Jan 05, 2009
  • 57 Answers
Read the service manual online
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
open the case and make sure the plugs from your power button and power supply are seated properly.
Posted on Dec 02, 2008
T3600 amber light stays on when I try to boot
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Apr 15, 2014 | Dell OptiPlex 740 AMD ATHLON X2 3600+...
Power button stay amber, dont finish booting
Generally, this is an indication of a motherboard failure. Remove any items connected externally and and expansion cards intenally and see if the Power LED indication changes. if not changes, then replace the motherboard
Mar 31, 2009 | Dell Dimension 3100 PC Desktop
AMBER LIGHT ON?
can you try this? unplug the pc, hold down the power switch until the amber light goes off, then (with the pc still unplugged) push the power button to see if the amber light comes back on, if it does, repeat the first step. do this until no light comes on when the power button is pushed. after you've done this. plug the pc back up, then hit the power button. what happens?
ive had this happen to a lot of my dell pc's here at work, but all i can figure out is that its a mobo problem, i also have tried swapping PSU's, but it didnt help.
Mar 16, 2009 | Gateway Computers & Internet
Hi... When I push the power button on my HP Desktop, just the amber light in the button comes on....nothing else. No noises (hard drive spinning-up, fan, etc)...nothing.
The amber light is signifying an error. Most common are the power supply, video card, or RAM. Worst case is motherboard has went bad. Try reseating the RAM without installing the video card, if it boots then it's the video card. Replace the bad part & you should be up & running again. Hope this helps & please remember to rate my answer. Thanks.
Jan 02, 2009 | E-Machines eMachines Desktop PC
Screen says attention no signal
Your TV is probably on the PC mode and you are not using it as a PC monitor.
You need to change the source by pressing the TV/Video button on the remote control or the SOURCE button on the TV itself. You may also just press the channel up or down buttons. Do this before the TV goes to standby mode (amber light) or while it shows the message: ATTENTION NO SIGNAL.
If it does not work, reboot the TV first and do this again.
May 17, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Monitor
OPEN MONITOR , look inside the PC BOARD around the transformer area and look for a burnt solder or cold solder , re solder it , and try again , please rate solution , thanks AJ
Apr 28, 2008 | Acer AL2216W LCD Monitor
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Dell Dimension E310 PC Desktop Logo
148 people viewed this question
Alun Cox
