Question about Panasonic Televison & Video
I press tray open button. Display
Using a Panasonic DMR-E30 DVD Video Recorder. Disc tray will not open. I press tray open button. Display eventually says "OPEN". But tray will not open!
  • davepobst Dec 03, 2008
    Haven't opened DVD player yet and inspected it, but solution sounds right.
  • 734 Answers
"to unlock the tray I only had to hold down the 'power' and 'stop' buttons on the front of the recorder, at the same time"
Posted on Dec 02, 2008
  • futureloginn
    futureloginn Dec 02, 2008
    Some do all.......
    EX95 does:-
    DVD-RAM / -R / -R (DL) / -RW Yes
    +R / +R (DL) / +RW Yes
  • 1,550 Answers
This is a mechanically problem in your player .
You need to manually open to take out the dvd .
The rubber thread which should be connected to the motor inside the DVD player might have moved from its place.
You need to place the rubber thread to proper place.
  • Panasonic Master
  • 19,396 Answers
Unplug unit power cable and plug it back.
Try pressing repeatedly the eject button while you turn on the unit, do this a couple of times.
  • Ginko
    Ginko Dec 02, 2008
    This often happens when there is a disk stuck inside, or one of the tray gears is not well in place.
    The firs solution consists in pressing repeatedly the eject button while you turn on the unit. You may need to do this several times before it works.
    If this method did not work , it will be necessary removing the upper cover, and either removing manually the stuck disk, or examining the tray mechanism to fix the problem.
DMR ex83 disc tray not opening
With the unit turned off, press and hold the [STOP] and [CHANNEL UP] buttons on the main unit at the same time for about 5 seconds. (Ejection may take extra time depending on discs.)
DO THIS ON THE MAIN UNIT (NOT on the remote)
It worked well for me. Roget
Jan 27, 2014 | Panasonic DMR-E55 DVD Recorder
How to convert my Panasonic DMR -E30 dvd recorder from uk region to multi region format
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
Jan 17, 2008 | Panasonic DMR-E30 DVD Recorder
Error code FO6 onVCR SD200
It is due to busy and confused memory IC by so many unfamilier external commands. Just reset the device to its factory setting.
The ratings level returns to the factory preset. While the disc tray is open, press
[DRIVE SELECT] to select the DVD drive, then press and hold REC button and PLAY button on
the main unit at the same time for 5 or more seconds ("INIT" will appear on the unit's display).
Leave it for some time till initilisatin has beed done.
Jul 20, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
How do I select the recording speed "SP" mode on my Panasonic DMR-E55 DVD recorder
1 Press [< OPEN/CLOSE] on the main
unit to open the tray and insert a disc.
≥Press the button again to close the tray.
2 Press [W X CH] to select the channel.
To select with the numbered buttons:
3 Press [REC MODE] to select the
recording mode (XP, SP, LP or EP).
4 Press [¥ REC] to start recording.
Recording will take place on open space on disc. Data will not
be overwritten.
≥You cannot change the channel or recording mode during
≥[RAM] You can change the audio being received by pressing
[AUDIO] during recording. (Does not affect the recording of
Feb 02, 2010 | Panasonic DMR-E55 DVD Recorder
DVD-RAM will not eject via "OPEN" tray command
Hey I just found out how to UNLOCK the tray
Power up the unit, wait for it to read the disc if one is inserted.
hold the stop button and the power button down together for 5 seconds
the display will show UNLOCKED
Open/close button should be restored
Apr 03, 2008 | Panasonic DMR-T2020 DVD Recorder
Locked DVD Tray
I'm pretty sure the force disk eject is the same across all Panasonic models - however I couldn't find anything specific for your model number. Still worth a shot, though.
With the unit in standby, press and hold the 'Stop' and 'Ch up' buttons together. It should power up and force the tray open. If this doesn't work, try changing up your timing by pressing and holding 'Stop' first, then a half-second later, press and hold 'Ch up' and keep them both held together. You can also try the opposite.
If none of these work, it will have to be taken apart to get the disc out. If you aren't comfortable trying, it will have to go to service.
Mar 09, 2008 | Panasonic DMR-HS2 DVD Recorder
LK ON on display
I had to call customer service to find this out: press and hold the stop and power buttons at the same time. A lk Off message will appear and everything should be fine.
Hope this helps.
Dec 14, 2007 | Panasonic DMR-ES20EG DVD Recorder
Panasonic dvd recorder
disk came off of the tray inside. unplug and open it maually.
Dec 03, 2007 | Panasonic DMR-E55 DVD Recorder
Tray will not open
put the machine in standby mode (ie switch power button on machine or remote) then, press and hold the STOP and CHANNEL UP buttons simultaneously. This will force the disk tray to open.
Apr 28, 2007 | Panasonic DMR-ES10 DVD Recorder
Televison & Video Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
