Question about Kenwood iTECH iQfive iQplus TK250-350-353-430-431 Compatible Two Way Adapters 2-Way Radio
No Display Dead Radio Kenwood TK 350 G
We get many of these very nice older radios for service. I am aware of the one popular fix for the above listed problem. The SMT crystal under the top cover by the knobs and display can be defective or the radio falling to the ground dislodging the chip crystal from the board.
BUT we have several 350 G's in the shop with the above listed problem and it's NOT the easy fix of the crystal. Using substitute bench supply and the fuse is good. I hear a little pop in the speaker, when first turned on........Dead radio....no display. What suggestions do you fine folks have so I can get these units back in service.
Thanks ..................fred Greenville Pa.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, have you tried a reset? Additionally, pls check for:
  • +4.5 at pin 21 of uPD7225 through R71 & R2; and/or
  • +4.6 at pin 58 of 75P116 through L1 & R92 from regulator IC7;
  • resistance of the center leg of the crystal to GND, 33ohms.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 02, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 2,326 Answers
I would suggest to inspect all the solder joints using at least 10X microscope as well check for proper crystal oscillation. If everything looks normal then check the transistor(s) that turn the back light power ON for the LCD driver IC.
  • 734 Answers
there is sum loosing wire problem in the display.
    Genius:
  • 1,239 Answers
Hi i think the circuit is weak......it is better to solder and then see the speaker.i think it will work thank u......please rate it
    Genius:
  • 1,550 Answers
The fuse is most likely to be blown out .
Other chance display may have contact problems .
Programming a TK-5320 using KPG-112DN V.2.20 keep getting "LOC" in display before the name of the channel.
Yes, radio. Check your cable. Is it OEM? Try plugging it into the radio before launching the software. Then try after launching the software. Is it a USB or Serial cable? If serial, the USB adapters often do not work. I have one brand of radio where I need to restart the computer each time I program so it will read the Serial to USB correctly. Even then, I may need to go into device manager and enable/disable it 2-5 times. I do not know if the software is the latest, but if a radio is programmed with the newest software, you cannot go back to an older version 90% of the time.
Aug 08, 2016 | Kenwood Radio Communications
How do I reset my KENWOOD TK-3170-K 4 to original settings?? Thank you!!
- Power the radio OFF
- Power the radio ON
- Push and hold The UP arrow, DOWN arrow, and MON keys and power the set ON
- Release the keys when the message rESt (reset) appears on the display.
Need the manual? You can download and print it, at no cost, here:
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Communications/LMR/Manuals/TK-3130_B62-1486-20.pdf
Bill B.
Nov 22, 2010 | Kenwood Protalk XLS TK-3130 (2 Channels)...
How do i program my kenwood tk260
You'll need the Kenwood serial cable and software to program this radio. Your best bet would be to contact a Kenwood Customer Service Representative directly. You should have the the radios in front of you when you call so that you can answer questions about them instead of having to call back, etc.
Kenwood contact information can be found here. The TK-260 radio falls under the "Land Mobile & Business" category.
Please rate this reply if helpful - good luck!
Aug 12, 2010 | Kenwood KNB-15AM,...
I have an older kenwood tk 270 radio. im having trouble puting it in programming mode. iv followed the instuctions to hold the light and dial buttons while turninging radio on but nothing happens got any...
These radios can be programmed via the keypad. However, this option must be enabled through the software, and must have a component removed from the circuit board. If you have a radio that will not go into self-programming mode when you use the proper key combination (light button+dial button while turning the radio on), your radio has not been enabled for this option.
programming instructions:
http://www.repeater-builder.com/kenwood/field-programming-tk-x70.html
Feb 15, 2010 | Kenwood Radio TK 260 360 270 370 2100 3100...
Progamming software for kenwood tk-270g
kpg56d is the software you will need for that radio.
Also here is a link to the service manual
http://download.qrz.ru/pub/hamradio/schemes/kenwood/TK-260G_ser_man.pdf
Aug 18, 2009 | Computers & Internet
TK 380 diplays "FPU OLD!"
This means that you need an older version of software. to program the radio. When it comes to Kenwood the newer version software will not program the older FPU Version radios.
Patrick Patterson N5SLI
Radio Service tech Manager
May 30, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
How can I program my Kenwood TK-3101 Radio?
Here is a link to the Kenwood TK3101 Manual which explains how to program this radio.
http://www.hitechwireless.com/pdf/Kenwood/TK3101-manual.pdf
If you need custom programming please contact us.
HiTech Wireless 888.511.5162
Mar 18, 2009 | Kenwood TK-3101 Radio
TK 380 not transmiting
Its most likely was programmed with a rx but no tx. Meaning it can recieve but not transmit, you can fix this with the programing software.
Jan 25, 2009 | Kenwood KNB-17AM, TK-280, TK-290, TK-380,...
Fixing kenwood tk-80
If you have the schematics try to follow the voltage lines with a volt meter. If this is beyond your capabilities then I would suggest taking the radio to a service center or sending the radio to Kenwood.
Nov 18, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Kenwood iTECH iQfive iQplus TK250-350-353-430-431 Compatible Two Way Adapters 2-Way Radio Logo
51 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
