Washing machine sometimes does not go through it's cycle
Suspected belts slipping but I've since stripped it down and the motor bearings are worn ,I can't see how to remove the bearings, is this possible or do I have to buy a new motor.I live in England so parts for these older models are hard to get I would just like to add that this is the first time this washer has ever gone wrong ,it is brilliant .Thanks in anticipation steve
  • arthurtours Dec 02, 2008
    hi barkencoa It's a maytag toploader la212 washing machine I've got the motor out but cannot see how it comes to bits thanks steve
  • Barry Coates
    Barry Coates May 11, 2010
    Hi Steve.
    I don't know if you have sorted your problem out yet, but depending on make of washer, it is possible to replace the bearings.
    Come back to me if you need more info.
    Cheers
  • Washing Mach... Master
  • 3,463 Answers
Hi Steve
If he motor is welded or riveted together. then you will not be able to change the bearings, if however it is fastened together with screws, then it may be possible to replace bearing(s).. you will only find out if you can disasemble the motor..
Good luck.
Posted on Dec 02, 2008
The door is closed good. However, the washer will not spin.
if it spins slowly but atleast spins? You may have a slipping clutch, bad brake assembly or if belt driven a loose or worn belt. maybe even a worn down motor coupler
Sep 15, 2014 | LG WM1814CW Front Load Washer
My Whirlpool Estate topload washer agitator will not spin in spin cycle & makes grinding noise
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jul 09, 2014 | Whirlpool Washing Machines
FLC271W2 washer squeal during wash cycle
LOUD NOISES IN washing MACHINE;
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
May 23, 2014 | Frigidaire Washing Machines
Belt slipping off
did it sound loud on spin if it did
check your bearing as they may be worn and need replacing
or your pulley may be damaged
Jan 11, 2014 | AEG Lavamat 74640 Front Load Washer
Admiral washer repair
Might be the drive belt slipping on the pulley. The belt that supplies the power from the main motor to the drum sometimes slips at higher speeds and needs the belt tensioner adjusted to tighten the belt. A more expensive reason for the noise is a worn bearing in the main motor.
Dec 25, 2013 | Washing Machines
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
The belt slipped off my indesit wib101 washing machine but it hasnt snapped or anything will i need a new belt completley or can the old 1 be replaced its first time this as happened and washing machine is...
Hi, If the belt shows no sign of wear and its not torn or cracked then you have nothing to loose in trying to put it back on, some machines have a tensioning bolt that can be undone slightly so the motor can be moved down to tension the belt if it seems loose and others do not, but if you anre unsure you can always get a new belt anyway.
Another consideration is that the machines bearings may be getting worn, making the pully go out of alignment (hence the belt coming off), check this by gently pushing the front rim of the stainless tub up and down, if you can feel movement it may be worth getting it checked for bearing failure with a view to getting them replaced.
Hope this helps.
Feb 13, 2011 | Indesit Washing Machines
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
Pump works. Spins when empty/no load in tub. clutch slips when loaded
If the drive belt is slipping during the agitate and both spin cycles for loaded conditions, I suspect that the drive belt is excessively worn. If it slipped only during a loaded spin cycle, I would have suspected that the sliding motor mount is gummed up and not moving to a belt tighten position during the start of a spin cycle. Since the unit drains with no problem for loaded and unloaded conditions, the pump belt should be OK. Replace the drive belt and clean the dust, gunk, detergent, etc, out of the sliding mount to make sure that it tightens properly when a loaded spin cycle starts. Note that on most models, the drive belt is designed to slip when spin cycles first engage, and they will continue to slip until after the drum has accelerated.
Sep 23, 2009 | Whirlpool LSR5132PQ Top Load Washer
Won't spin
Sounds to me, your belt is slipping. The motor tensions the belt with springs. The motor slides in grooves to keep the belt tensioned. These grooves get gooked up with dust, dirt, rust, slime, etc. Move the motor back and forth a few time to clean the grooves. Also spray some lubricant on it to help clean it and make it slide freely. Be sure both sides slide back and forth in their groove. After doing this, your belt should stay tensioned enough not to slip during the spin cycle. No tools needed and even the average moron could do it. Hope this helped.
Sep 30, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
