Question about Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo
Cannot figure out how to remove stand so I can mount TV on wall
I bought the 20 in Sylvania LCD/DVD combo and cannot figure out how to remove the stand the tv sits on so I can mount it on the wall. We tried removing the screws but still it not come off. It has the holes in the back of the tv to mount it so we did mount it on the wall but the stand is still attatched. Can you help me ?
  • 1 more comment
  • psveers Dec 28, 2008
    I have a Sanyo 37" Flat Screen TY and want to wall mount it. The instructions for removing the stand say to remove the four screws in back. They can be loosened, but since they are in recessed holes, there is no way to pull them out. The stand will not come off no matter how much I loosen the screws. The base of the stand can be removed from the center post and the unit can be mounted on the wall with the center post attached, but I can not figure out how to get those four screws out.
  • kim1968 Feb 02, 2009
    OK. So we figured out how to remove the stand from the 20 in tv. My husband was removing the wrong screws. Duh... But anyway like the person with the 37in two of the screws did not fall out. I guess we will leave them in there. At least the stand is off now.
    Thanks
  • jules10646 Apr 14, 2009
    We just purchased the ld320ss8 32 tv/dvd combo and cannot figure out how to remove the stand. We have it mounted to the wall but want to remove the stand. We have unscrewed all of the bottom screws and the two on the side that we had to pull out with a smaller screw driver for them to come out.... but it's still hanging on??? How do you remove this thing?? Are there some kind of hooks inside? Do you have to push the sides in or tilt it? Has ANYONE gotten their stand off????
Did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Posted on Feb 01, 2009
SOURCE:
Jvc lt-22dd4wj combi tv original stand
I am looking for a tv stand for JVC LT-22DD4WJ LED/DVD COMBO,
as I have broken the original stand
Robert Hanslip
May 11, 2013 | Televison & Video
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Jan 04, 2009 | Soyo DYLT032D 32 in. LCD Television
Trying to remove tv stand base from unit
Assuming you got the stock mount off your Sylvania Model LC320SS8, I would like to purchase it from you.. Interested... please call me.. 360.510.4656
Thanks..
Gary
Nov 26, 2008 | Sylvania LC320SS8 32 in. LCD Television
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Removing stand to mount on wall
Just called the company and was told that you simply remove the 4 screws on the back of the stand that is holding it to the tv....They do NOT recommend mounting the TV because it will make your warranty ineffective-per the rep.
Jul 23, 2008 | Sylvania LC320SS8 32 in. LCD Television
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Sylvania 6620LDG 20 in. EDTV-Ready LCD TV/DVD Combo Logo
1,231 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
