Question about Brother MFC 7420 All-In-One Laser Printer
I have a brother mfc-7420 flatbed and am trying to scan multiple pages through the automatic feeder but it only scans whats on the flatbed? Is the feeder only for copies and not for scans? Anything i can do? thanks
First install everything, than go to my computer at the bottom u will have Scanners and Camera, click on Brother MFC-7420 USB
Than if the window pop ups than click on Microsoft Scanner and Camera Wizard
Now u will have new Window "Scanner and Camera Wizard" click Next
On next page u will see Choose Scanning Preferences in there u will find "Paper Source"
click on the Scroll down option and pick "DOCUMENT FEEDER" and Click next
than hopefully u know wat to do pick the name fro scans that u going to make pick the folder to place it in and it will start scanning by it self and will send i to ur computer.
And put ur Scan paper with the side that u wanna scan FACE UP in the FAX tray which is on the Top or all in one Printer
Posted on Dec 17, 2008
Why is there a black line on copies when pages scanned with automatic document feeder but fine when using the flatbed scanner?
Different paper path, the MultiFunction unit is dirty - Most likely toner inside the roller or paper path. Try a laser cleaning cloth that you can buy in some stores or online. Search: Staples
Aug 05, 2014 | Brother MFC 7360N - Multifunction fax /...
When I use the printer to scan via the document feeder, I get two parrallel lines down the right hand side of each page of the pdf. I've cleaned the glass and everything else but still get the lines....
Open the scanner cover and you will see two glasses. One long and thin and the other larger than an A4 sheet of paper. The long thin glass is used to scan thru the adf and the larger glass is for flatbed scanning.
As your lines are from the adf scanning, you will see tippex on the long thin glass. just clean it off and all will be well. Clean the flatbed glass as well while you are doing the job on the adf glass.
Sep 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
Scanning images onto mac
The scanner driver is separate from the printer driver. This link will take you to the downloads page of Brother-usa.com, where you select the machine family, then the specific model. Click the downloads link at the bottom, then, and you'll get to a page to select what you want and for what OS. Brother lists Mac os's from 9.x to 10.6.
Even if you have a driver on CD, the website usually has a newer version.
Jan 21, 2010 | Brother MFC 7420 All-In-One Laser Printer
Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Sep 18, 2009 | Brother MFC-7820N Laser Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Mar 21, 2009 | Brother MFC-7420 Laser Printer
Brother MFC-465CN How can we scan multiple documents?
Make a stack of the documents you want to scan and load them in the automatic feeder: The page to scan facing upward, and the top of the page inside. Press the Scan button and start (color or black).
If you choose the pdf format, you will have them in a single file.
Hopr it helps.
Feb 18, 2009 | Brother MFC-465CN InkJet Printer
Problem with scanning documents through feeder
you can scan only one doc at atime on this machine.
Nov 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
Printer
In general the upper left corner of the glass. However you may need to tell your Brother what size the original is. Should be no more than pressing another button or two.
Henry
Jun 03, 2008 | Brother MFC 7420 All-In-One Laser Printer
Scan Photos
u put ur picture on glass of scanner . and give command to scanne after scanning computer will ask in which format u like to save ur file
Brother MFC 7420 All-In-One Laser Printer Logo
463 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
