Question about Frigidaire GLMV168K Microwave Oven
Frigidaire over the oven micro
GLMV168CB1 Microwave. My wife inadvertantly turned the micro on for 45 minyutes with nothing in it and after running for 37 minutes it stopped and nothing. I have NO power, no usdage. I reset the breaker nothing, any suggestions?
  • Anonymous Jun 16, 2008
    I own a PLMV168CC1 and the turn table does not turn and it does not heat. Everything else works and the time counts down as if it is cooking.
  • Nextime Aug 13, 2008
    My over the oven Frigdaire stop heating should I buy a new one, can someone come in and fix it what is cheaper
  • Frigidaire Master
  • 9,156 Answers
The magnetron will have overheated and will need to be replaced. Also, there is a thermal cutout mounted on or near the magnetron. It will need to be replaced, too. You can find exploded views and order parts here: http://tinyurl.com/gv383 What you'll need are the parts marked as reference numbers F73 & F74 (73 & 74) on diagram number 6. You might also be able to find cheaper substitute parts at a local applaince parts store. You can find critical safety and disassemby tips at our site via our FixYa listing: http://tinyurl.com/yzjozk
Posted on Jan 31, 2007
SOURCE:
GLMV168 Frigidaire over-the-counter microwave oven. My wife inadvertently let it run for about a minute with steel utensils in water in a glass jar along with plastic dishes. She says there was a small...
Hello Robert, I am happy to assist you. Let's try resetting the microwave by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit on. If the issue persists, then based on the symptoms you are describing, it could possibly a faulty fuse or the main control board. If the instructions above do not solve the problem, I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Aug 11, 2013 | Frigidaire Mid-Size Microwave
Frigidaire control panel has no power
Check those 3 micro switches in the door latch assembly. "my husband says that if you push the door it will work."
Nov 24, 2017 | Frigidaire GLMB209D Microwave Oven
Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Mar 13, 2010 | Frigidaire FMT148GP Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Light and timer work on microwave but oven does not start or turn. I had just finished microwaving a veggie and it worked fine.Now nothing. Made in 2004
The door interlock switch is most likely the problem (Probably the primary one). This switch goes bad quite offen. The switch or switches can be replaced. They are either in a cluster where all switches are replaced at once or are individual micro switches where each one is replaced individually
Aug 14, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Nothing works
Check the ceramic fuse it is easy to spot under the top of the machine cover
May 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidaire F3 problem
thank you, problem resolve....bought new micro
Mar 22, 2009 | Frigidaire FMV145K Microwave Oven
Shuts Off after 22 seconds
Time to buy a new microwave as it sounds as if the control panel is defective. A new control panel for this micro will run about 95 to 120 bucks + labor depending on where you buy it. I happen to like slightly burnt popcorn as well!! Nothing wrong with thats, as they say great minds think alike.
Aug 25, 2006 | Panasonic NN-S933BF Microwave Oven
Frigidaire GLMV168K Microwave Oven Logo
354 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Jaime Hernandez
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
