Question about Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
I accidently deleted svchost.exe from doing a virus check. I now cannot lonto windows. I can log into my username and the system logs off again. I have tried expanding the file svchost.ex_ file in Dos and I get confirmation file has been expanded however I still cannot log into windows.
  • hayatrocky_2 Dec 02, 2008
    slow warking
  • pipponio Jan 02, 2009
    My antivirus software (AVG) have found (and deleted) a virus identified with svchost.exe. The virus was really there because strange things happened. After this, i can login with my username but i get disconnected immediately.
    President:
  • 2,110 Answers
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Posted on Dec 02, 2008
    Problem Solver:
  • 5 Answers
Your system should restore all damaged drivers when the recovey disk is used. You should be able to select repair or recovery from your OS install disk. I can't offer any more specific info, as I do not use XP, but this technique worked when my Windows Vista and Windows 7 PCs lost the boot manager
Posted on Mar 18, 2009
  • 43 Answers
This is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
usually when that happen the only solution is to reinstall the OS. even try to fix it from the registry key, the key and the pointer will be there, but not the excution file, and there is not way which svchost control what services.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services allows for better control and easier debugging.
Svchost.exe groups are identified in the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the registry key.
Posted on Mar 09, 2009
    Problem Solver:
  • 3 Answers
please try this:
1- put the windows CD in ur CDdrive.
2-change the BIOS settings to reboot from CD.
3-when rebooting from CD choose repair windows
Then let the system fix it self.
I hope this will work.
thank you .
Antivirus for ''doomsday'' virus
I had this virus, and the following procedure seemed to work in getting rid of it for me. Hopefully it works for you as well.
open command prompt my going Start > Run and typing cmd.
You should be in a directory called something like “C:\Documents and Settings\User”. if you are not, change to it by typing ‘cd’ and the directory above (replacing ‘user’ with your username), and then pressing enter.
type ‘attrib’ and press enter. There should be a file called svchost.exe, and will have the attributes SHR (which stands for System-file, hidden, and read-only).
type ‘attrib -s -h -r svchost.exe’. This removes the SHR properties and allows you to delete the file.
type ‘del svchost.exe’. This should delete the virus from your computer.
NOTE: svchost.exe is a critical system file if it is located in C:\WINDOWS\System32. If it is located elsewhere (as this one is), it is generally a virus.
Then, insert infected pen drives (memory sticks, iPods etc.) which carry the virus. Change the directory to the pen drive by typing ‘E:’(or whatever letter it is) ENTER. Then type ‘attrib’ as above.
there should be the files ‘protector.exe’ and ‘autorun.inf’ which also have the properties SHR. type ‘attrib -s -h -r’ ENTER, and then delete the files by typing ‘del autorun.inf’ ENTER then ‘del protector.inf’ ENTER. This should remove the virus. Autorun.inf might reappear, but this shouldn’t be a problem.
Do not open the pen drive after you insert it, and cancel any autorun windows that come up.
May 13, 2010 | Computers & Internet
I'm receiving 2 messages from my webroot internet security essent
This sounds like a virus to me? you say you are receiving that message, please, is it Windows "Telling" you?, or some program "Telling" you? please clarify? svchost, is not something that should be deleting anything...Both TCIP & netbt are VERY important part of Windows, so I do NOT think, it should be allowed.
Feb 28, 2010 | Webroot Internet Essentials (83210)
Everytime i open my computer, ah pop-up windows say's WINDOWS CANNOT FIND SCVHOST.EXE
First, I'll let you know what's going on, then I'm going to post from Microsoft, what svchost.exe does, and how to find out where the problem is. I can help you further if you need it.
Svchost.exe is a program in WIndows XP Pro that will start services in your computer during startup. It sounds like you have deleted a program and "service host" is still looking for it to open on startup. This can happen if the program was removed without using the correct removal procedures. It is still listed in the registry and your computer is still trying to access it. DO NOT edit your registry unless you know what you are doing. You could create a catastrophic failure of Windows. There are programs that will remove registry entries if those entries are no longer valod. You can fing a free program for this function at web sites like www.nonags.com
Following is information from the Microsoft web site:
Svchost.exe groups are identified in the following registry key: HKEY_LOCAL_MACHINE\Software\Microsoft\WindowsNT\CurrentVersion\SvchostEach value under this key represents a separate Svchost group and appears as a separate instance when you are viewing active processes. Each value is a REG_MULTI_SZ value and contains the services that run under that Svchost group. Each Svchost group can contain one or more service names that are extracted from the following registry key, whose Parameters key contains a ServiceDLL value: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Service To view the list of services that are running in Svchost:
  1. Click Start on the Windows taskbar, and then click Run.
  2. In the Open box, type CMD, and then press ENTER.
  3. Type Tasklist /SVC, and then press ENTER.
Tasklist displays a list of active processes. The /SVC switch shows the list of active services in each process. For more information about a process, type the following command, and then press ENTER: Tasklist /FI "PID eq processID" (with the quotation marks) The following example of Tasklist output shows two instances of Svchost.exe that are running. Image Name PID Services
System Process 0 N/A
System 8 N/A
Smss.exe 132 N/A
Csrss.exe 160 N/A
Winlogon.exe 180 N/A
Services.exe 208 AppMgmt,Browser,Dhcp,Dmserver,Dnscache,
Eventlog,LanmanServer,LanmanWorkstation,
LmHosts,Messenger,PlugPlay,ProtectedStorage,
Seclogon,TrkWks,W32Time,Wmi
Lsass.exe 220 Netlogon,PolicyAgent,SamSs
Svchost.exe 404 RpcSs
Spoolsv.exe 452 Spooler
Cisvc.exe 544 Cisvc
Svchost.exe 556 EventSystem,Netman,NtmsSvc,RasMan,
SENS,TapiSrv
Regsvc.exe 580 RemoteRegistry
Mstask.exe 596 Schedule
Snmp.exe 660 SNMP
Winmgmt.exe 728 WinMgmt
Explorer.exe 812 N/A
Cmd.exe 1300 N/A
Tasklist.exe 1144 N/A
The registry setting for the two groupings for this example are as follows: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Svchost:
Netsvcs: Reg_Multi_SZ: EventSystem Ias Iprip Irmon Netman Nwsapagent Rasauto Rasman Remoteaccess SENS Sharedaccess Tapisrv Ntmssvc
RApcss :Reg_Multi_SZ: RpcSs
Jun 18, 2009 | Microsoft Windows XP Professional for PC
Svchost.exe problem
i think its a virus or a worm problem to get rid of this go to my blog and download quickheal two months full verion scan it will clear your problem
dont forget to turn off system restore before installing and upto completing the complete scan of your pc
bye bye
http://xviruslab.blogspot.com
Feb 28, 2009 | Microsoft Windows XP Professional
Svchost.exe boot up problem
Virus worm...get a good antivirus not a trial version
Try this
Your files must be un-hidden (Files option)
Here is the site that will help you
http://www.plumchoice.com/tempfiles5.html
Feb 27, 2009 | Microsoft Windows XP Professional for PC
I have deleted svchost.exe accidently from windows xp and cannot now log onto windows. I have tried expanding the file from dos however still cannot log on
this is going to be a tough one to fix. since I don't know which svchost you have deleted from the system.
Dec 02, 2008 | Microsoft Windows XP Home Edition
Unknown file
In software Svchost.exe is a generic host process name for services that run from dynamic-link libraries (DLLs) within the Microsoft Windows operating system.
At startup, Svchost.exe checks the services part of the registry to construct a list of services that it must load. Multiple instances of Svchost.exe can run at the same time. Each Svchost.exe session can contain a grouping of services. Therefore, separate services can run, depending on how and where Svchost.exe is started. This grouping of services permits better control and easier debugging, but it also causes some difficulty for end users wishing to see the memory usage or vendor legitimacy of individual services and processes. End users in Windows XP Professional (and derivatives, such as Windows Server 2003 and Windows XP Media Center Edition) can run the following command at the system prompt to get a breakdown:
tasklist /svc /fi "imagename eq svchost.exe" (NB: This command does not work in Windows XP Home.)
Due to being widespread among running processes, svchost.exe has long been a common disguise used by malware to hide its presence from the user. (One of the common trojan horses deceptively uses scvhost.exe). Users may then run tasklist with no arguments and match the reported PIDs with the previously shown Svchost instances. If memory usage appears abnormal, the user can look up the service names shown by their command on the internet to see if it is a known service or malware.
The Svchost.exe file is located in the %SystemRoot%\System32 folder. The main registry key involved at bootup is HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost (values in this key will show the user at least a partial list of the actual processes behind instances of svchost).
The 30 April, 2007 release of WSUS 3.0 led to reports of svchost.exe issues, including 100% CPU usage, memory hogging, and excessive laptop fan/power usage.[1]
[edit] See also
Oct 29, 2008 | Microsoft Windows Server Standard 2003 for...
Svchost
"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging. The svchost.exe file is located in the folder C:\Windows\System32. In other cases, svchost.exe is a virus, spyware, trojan or worm! To detect if it's a virus sometimes it will add letters to the Svchost to read thus SSVCHOST or SVCCHOST or something like that, thus making multiple services to run and slow down the computer, if that is the case the current antivirus you are using is not removing the virus, this can be done in the registry, its a complicated process if you do not know how to do it, so i would suggest you purchase a registry cleaner. NOTE: remember to backup the registry before you clean it
Aug 15, 2008 | Microsoft Windows XP Professional
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
Svchost.exe
Go to start>all programmes>accesories>system tools>system restore and restore the pc to a date before you deleted the file
Nov 01, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows XP Home Edition Logo
2,070 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
