Question about Lucent PARTNER18 Corded Phone
Change the amount of rings
When incoming calls come in, the phones rings 2 x and go into voicemail. I would like the phones to ring 4x before going into voicemail
  • pfsllc Mar 06, 2009
    Phone rings about 1.5 times before going to voicemail. I need it to ring at least 3 times.
    Champion:
  • 211 Answers
On ext 10 press feature 00, left intercom twice, #506, mode 1, line 01, press 3.
Do this for all of your lines
Posted on Mar 19, 2009
THANK YOU!!
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
Mobile phone,all incoming calls go to voicemail,without ringing
you did not provided what brand, model and year, therefore you need to read your manual...
you need to find in your setup section and enable calls, setup as to re-direct to voicemail after say 5 rings, enable ring.
unfortunately without model and year - more detailed directions cannot be provided...
Feb 08, 2015 | Cell Phones
How do i change the number of rings before voicemail picks up on a samsung rugby
For all of you that want a real answer here ya go. This isn't something you can change on your phone this has to be changed with your service provider. If you are with AT&T, like I am, then this is the solution for you (link of where I found it below as well). 1. enter *#61*11# and press send/talk on your phone.
2. write down the number your calls are currently forwarded to (usually +1401#######, but not always). this is your voicemail deposit number.
3. decide how long you want the phone to ring in 5 second intervals. the maximum time is 30 seconds. i'd recommend 25 seconds or less, as using 30 may cause you to be billed for a minute of airtime each time someone is forwarded to voicemail.
4. now enter **61*[number from step 2]*11*[number from step 3, use 2 digits]# and press send/talk.
example
voicemail deposit number is +14015551212
you want it to ring for 20 seconds
you would enter **61*+14015551212*11*20# and press send/talk.
if you have trouble with the above procedure, you can always call customer care at 800-331-0500 to change it.
OR QUESTION: How can I adjust the number of times my wireless phone will ring before the caller goes to voicemail? ANSWER: Contact Customer Care at 1-800-331-0500 or dial 611 from your wireless phone to change the amount of time your phone will ring before going to voice mail. The adjustments made by Customer Care are based on the traditional ring heard by the caller, not the unique Ringtone you hear from your phone. I just wanted to add that increasing the ring length to 30 seconds will not cause you to be charged a minute should the caller go to voicemail. This was confirmed by an AT&T technician.
http://forums.att.com/t5/Voice-Mail/Increase-the-number-of-rings-before-a-call-goes-to-the-voicemail/td-p/2576651
Aug 11, 2011 | Cell Phones
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
Nortel T7316E Voicemail
It sounds like both phones are set to ring on incoming calls and both phones are set to call forward to voice mail box with the same amount of rings . you should turn off the ringing for both phones that way it will not jump between the to mail boxes . now when a call is trans it will go to the box .
Mar 24, 2009 | NorStar T7316E Corded Phone
Changing amount of rings when going to voicemail
The call forwarding was turned off. To turn on, press speaker, enter 793, press 1(for set), press extention number, and enter 300. If you have call forwarding on and are looking for more rings, do the above steps except press 2 (for clear).
Nov 19, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Incoming calls
i would got into your voicemail settings and check to see if you have it set to ring once then straight to vmail.. i'm not sure how your phone is set up completely but i would assume you can adjust the amount of rings before vmail picks up.. is this phone new to you?
hope this helps..
d
Feb 21, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Length of time phone rings with incoming calls
get your mailbox number then type in **61*44then mailbox mumber*11*then a two digit number between 00 and 30 (seconds delay).
Feb 19, 2008 | RIM BlackBerry 8800 Smartphone
Lucent PARTNER18 Corded Phone Logo
182 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Computer Repairing
Computer Repairing
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
