Question about Cuisinart DLC-10S Pro Classic Food Processor
Installing Cuisinart Sleeve/Sheath for DLC -7EMotor Shaft Cover
I have had to order part.. Cuisinart sells parts with out instructions... I'm hoping some one can email me instructions.... I have been told it can be tricky to install... TL
  • 1 more comment
  • kaktak Dec 28, 2008
    I have the same problem. I just ordered the part yesterday. My food processor DLC7Pro is 26 years old, and I have replaced the sheath at least twice. The trick is to get the old one off. When my part arrives, I'll email you back and let you know how I did it. Sorry that I can't remember off the top of my head, but it can be done!
  • nbarengo Dec 29, 2008
    same problem here, could somebody help? thanks
  • juliachild Jan 12, 2009
    The same thing happened to my CFP-9A motor shaft cover this weekend after 31 years of hard use. I've ordered the part, and was hoping it would come with instructions. Sounds as thought it won't.
    Would be grateful for any insights from your experience.
I have a DLC 7 pro circa 1982 - just replaced the sheath. First - remove old sheath - I found that using a plumbers pipe cutter to cut old sheath off in sections then pulling each section off with pliers works great. Make sure ALL the plastic comes off the metal shaft - as well as the brass ring portion of the sheath.
Next use a sharpie marker to mark the the "flat" side of the shealth = you must look inside the sheath, find the 2 "nubs" that form a "flat" side. These nubs must line up perfectly with the flat side of the shaft - mark the base of the shaft as well so you can more easily line up the flat of the sheath with the flat side of the shaft (and no, the flat outer sides of the the sheath do not match up with the flat inside section of the sheath - that would make life too easy!)
Press the new sheath on with your hand as far as it goes - should go down to about 1 inch from the base.
Now you need a hammer, piece of 2 x4 wood and brute strenght! (keep in mind that once you hammer it - even once - it will NOT come off) Put the 2" side of the wood against the top of the sheath - Use a LOT of force to hammer the sheath all the way down. will probably take 3 - 5 good strikes. It will take much more force than you think you should need to use. Make sure the base of shaft is as far down as possible - if it rubs against the workbowl while spinning it will fuse to the bowl! Good luck! -
Posted on Dec 28, 2010
  • 8,596 Answers
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Posted on Jan 17, 2009
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
Replace the motor shaft cover on cuisinart dlc 7
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Dec 06, 2010 | Cuisinart DLC-10S Pro Classic Food...
How do you get the motor shaft cover off? I need to replace the old one.
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Oct 07, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Cracked plastic sheath on the motor drive shaft
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Instructions for Cuisinart DLC 054 Pasta Maker
I'm selling the Cuisinart DLC-054 Pasta Attachment manuals on CD on Ebay.
Feb 09, 2010 | Cuisinart Food Processors
I need to remove the plastic motor shaft sleeve from my Cuisinart DLC10. THe old one cracked, I have a new one but the old one won't slide off...
Many people have had this problem. When I called Cuisinart, they said, oh sure we will send you the part and instructions. When I called because there were no instructions, I got another story about how I needed to send it back because that repair is only made at the warehouse. I have found other places online where people just chip and pick at the plastic until it comes off. Short of sending it back and paying the shipping I don't know what else to say. My husband is chipping and picking as we speak.
Jan 02, 2010 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
Sure, you can find it on amazon, here: Amazon com Cuisinart Motor Shaft cover. Hope this was helpful. have a nice day
Nov 16, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
I have ordered a replacement stem for my DLC-7, the stationary stem that covers the motor shaft. I'm not sure how to remove the one currently on the unit.
Remove the pusher sleeve and lid from the work bowl first, then slide the work bowl out of the locked position. At this point, the stem should be exposed.
Nov 05, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC-10S Pro Classic Food Processor Logo
940 people viewed this question
Top Cuisinart Food Processors Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
downhille
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
