I have a Samsung DLP monitor (HL-P5063W) that was purchased in March of 2005 and has had no problems until now. It recently started turning itself off after the first 10-15 minutes. In the last week, it has been doing this repeatedly four or five times at startup. After that, it can run for hours and has no problems. No warning LED lights flash on in the front panel indicator area. The fan seems to be working fine, and the picture is still excellent. I've tried unplugging the monitor, waiting a few seconds, then plugging it back in and turning it on. (that's all Samsung could suggest when I called their customer service). Problem still occurs. I cannot afford to replace it right now, and I don't a means to take it to a service center. Any assistance would be greatly appreciated. FYI - I've worked with computers for 30 years, so I could probably handle any part swaps if that would be the problem. Thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, would suggest an exploratory check of the inside of the unit. The description that "run for hours...no problems. No warning LED...fan seems to be working...picture is still excellent" most likely indicates no major components at fault and therefore for the moment could be:
  • loose connection;
  • cold solder;
  • heat related problem.
Offhand, best approach would be to:
  • reference a service manual;
  • observe/measure voltages of critical components on both running/turning off conditions;
  • cleaning. checking of ventilation pathways, fan efficiency and the likes.
In the even that simple fixes would not be corrective, you may have to review your options.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 12, 2008
  • 76 Answers
Hello sir
if you can replace the power supply board.you can fix that trouble. i have the same trouble last week,if you want more cheaper try to replace all damage capacitor on that power supply
    Genius:
  • 1,550 Answers
You need too replace the DMD PCB and the DMD IC.It will cost you around $700 . You can get these parts from partstore.com
Posted on Dec 03, 2008
    Sergeant:
  • 217 Answers
Check out the EST in the monitor.
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
HI FOLKS, I HAVE A SAMSUNG HL-P5063W DLP TV THAT WON'T TURN ON. WHEN I PLUG IT INTO TO WALL I GET THE SOLID RED STANDBY/TEMP MESSAGE ON FRONT ON/OFF BUTTON. THEN WHEN I TURN IT ON, THE STANDBY/TEMP MESSAGE...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W DLP No. 1 fan problem
Defective Lamp,maybe and Ballast Board may well be the problem it is what turns Lamp on Look on line Encompass Parts Dist 1-800-638-3328 Ballast Board also has small fan mounted in front of it!
Nov 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-P5063W DLP rear projection LCD red
Make sure that, obviously it's plugged in at both ends properly, but also that none of the pins are bent or broken.
Jul 23, 2009 | Televison & Video
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Dec 07, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
