Question about Sanyo DS27800 27" TV
No sound can't find audio setup menu not in SAP audio menu only
    President:
  • 1,284 Answers
Some less expensive no thrills televisions don't have a audio menu. On those units the only audio functions you will have is to select between SAP or Stereo. Is it connected to a cable box? Does the cable box have a volume control? Can you get sound if a VCR or DVD is connected? Try those out.
Posted on Feb 01, 2007
Accidently pressed a button and lost sound on my 42
Go into customer menu and look both in setup and audio menus.
In set up are speakers switched on or off?
In audio menu which sound mode is selected? (Mono-stereo-sap)
Mar 16, 2012 | Televison & Video
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
I think that its a tuner problem, when im watching DVD its nice, but when im watching TV chanels the sound and the image are wrong! what do u thing?
Check on what mode is audio setup SAP MONO STEREO,that could be case.
On main menu AUDIO SETUP.... (chose STEREO recomended)
Aug 23, 2011 | Televison & Video
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
No sound,but good pic.everything else works fine.(toshiba 57hx94)
hello,
• Check the antenna/cable connections (see Chapter 2).
• The station may have broadcast difficulties. Try another channel.
• The sound may be muted. Press VOLUME.
• If you hear no sound, try setting the MTS feature to STEREO mode (page 81).
• Make sure the SPEAKERS function in the AUDIO SETUP menu is set correctly (page 83).
• If you are not receiving a second audio program from a known SAP source, make sure the MTS feature is
set to SAP mode (page 81).
• If you hear audio that seems "incorrect" for the program you are watching (such as music or a foreign
language), the SAP mode may be on. Set the MTS feature to STEREO mode (page 81).
• When using an external audio amplifier, if you connect the amplifier to the VAR. AUDIO OUT jacks, the
volume of the TV and amplifier must be set above 0 or you will not hear any sound (page 20).
regards
shaun
Dec 03, 2010 | Toshiba 57HX94 57 in. HDTV Television
My truflat is speaking spanish on some channels and some channels showing picture and no sound . and the when i turn stereo,mono,and sap pops up.
you have teh audio set in SAP mode. Some nits have the audio mode button on the remote. Otherwise go into the audio setup menu and choose MTS(stereo) or mono.
Apr 28, 2010 | Televison & Video
We have a tv where we are getting some chanels with out voice but others are fine, any idea
Try resetting the TV (look for through the Menu options for a Setup or Tools section and an item like Restore Default or Memory Recall). Then exit the Menu and return to the Menu and do a new channel scan.
Other resets can be done by unplugging the TV for a minute.
I hope this helps.
(I had a recent issue with one channel having no audio and another no video and resetting the TV's memory to the defaults and then rescanning worked.)
Apr 21, 2010 | Hitachi 42HDS69 42 in. Plasma Television
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
SAP
There might be a SAP button on the remote or under a cover on the remote, or it might be an audio button, you want Main or Stereo. I couldnt pull up a picture of the remote, but I would suspect that if the SAP function is not in the menu it is probably on the remote.
Jul 08, 2007 | Akai LCT3201AD 32 in. LCD Television
Sanyo DS27800 27" TV Logo
98 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
