Question about Dishwashers
My matsui mf2w/a dishwasher sticks during cycle. normally about 10 minutes into the wash. i can move it on manually but the wash is poor. the water does not appear to be heating
  • 1 more comment
  • sahabettin Dec 30, 2008
    Yes, Mine sticks too, exactly the same. When I moved the dial on slightly it did start to work again but took 9 hours to complete the cycle with what appears to have been cold water!! - HELP we've got a New Years party this weekend and I need my dishwasher - Desperate of Carshalton (Surrey)
  • pharmy Jan 08, 2009
    My Matsui has the same problem! I've changed the timer but no change! Has anybody solved this problem? I suspect it could be the heating element but I need some confirmation
  • kamadhead Mar 25, 2009
    Yes I am having the same problem with mine has anybody had any joy with fixing it yet??
Check the safety thermostat which is located at the bottom of the dishwasher. you have to remove the bottom plate,and then you will find easily the thermostat-KSD201/PF 90. you have to reset this probably.there is a red wax dot in the middle this thermostat, so remove it and use a needle to press a very small button inside. the heating element is working well probably.you can measure resistance on it to be sure.
Posted on Feb 02, 2010
How do you change the element in a Matsui MF2W/A
Posted on Jul 14, 2010
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Matsui dishwasher mf2w/a not heating
If your Matsui MF2W/A timer stops earlier in its cycle, turn off the water and unplug the machine.
Pull it out and put it on its back. Remove the base panel. Remove the anti-flooding interlock. Unplug the two cables feeding the heater element and check its resistance. Should be 30 ohm or thereabouts. If not the heater's defective and you should replace it.
Pull the cables off each of the two thermostats and check resistance. It should be in the order of .5 ohm or less. If the reading is high then replace.
Remember there are two thermostats fixed to the dishwasher pan. One at the right back lower, and one at the left back lower. For the left hand one you may find it easier to access by removing the lefthand dishwasher panel.
And that's about it. Job done.
Apr 06, 2012 | Dishwashers
White residue on dishes when the dishwasher cycle has completed, not sure why, salt is fine. Is this limescale?
Hi
Make sure that the water is being heated up by your dishwasher. Also need to make sure that the wash motor is spraying water around at full force.
Best way to check this is to start a normal cycle about 10 minutes into the cycle open the dishwasher door during the cycle. 1st observe if the water was being sprayed around as you opened the door. 2nd feel the water and see if it has heated up.
Reset or cancel the cycle and wait for the water to empty. make sure it is draining properly and also check to see if filter is clean.
I'm inclined to think your machine is not heating the water.
Ash
Sep 09, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a matsui mf2s/a dishwasher with no user manual i was wondering where i can get one from or how to clean the dishwasher out properly
You can download the manual for the Matsui MF2S / MF2W by clicking on the following link:
http://www.partmaster.co.uk/company/partmaster/manuals/Matsui%20MF2W%20-%20MF2S.pdf
The manual will open in a new browser window or you can click on the link with your right mouse button then choose "Save Target As..." from the popup menu to save it directly to your PC. You will need to have Adobe Reader or any other PDF file viewer installed to open the file:
http://get.adobe.com/uk/reader/
The instructions for removal and cleaning of the filters are in the manual, but if you need further explanation of anything please let me know.
Regards,
BElectric
May 01, 2011 | Dishwashers
I have a dish washer matsui model mf2w/a and the timer seems to be sticking causing the machine not to wash correctly, the machine carries on doing the same thing until i manually move the timer control...
Oct 19, 2010 | Dishwashers
We have a matsui mf160 dishwashwasher and it is struggling to get items clean - esp greasy items - i have also noticed it is not hot at the end of the cycle so i think the problem is there is no hot water....
The dishwasher's heater is likely shot. Get a new heating element. The same heater drys and the end but also heats the hot water during the wash cycle. No hot water = dirty dishes.
Mar 19, 2010 | Dishwashers
Extremely long cycle
The drying coil that is broken also heats the water during the wash and rinsing phase. Right now it is waiting for the water to heat up, that's why it's pausing. Replace broken heater, they are relatively cheap and can be gotten at repair clinic.com.
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
1,765 people viewed this question
Top Dishwashers Experts
