Colour code for 480v 3ph is it brn - orng- yellow?
    Problem Solver:
  • 15 Answers
Most typical local practices are; (Brown-Orange-Yellow) for 480VAC 3Phase
The US National Electrical Code only mandates white (or grey) for the neutral power conductor and bare copper, green, or green with yellow stripe for the protective ground. In principle any other colors except these may be used for the power conductors
Posted on Dec 03, 2008
Colour of EU flex
The flex will have brown and neutral, same as UK. If it does not, seek more help.
Dec 21, 2013 | Cars & Trucks
Switch to switch colour code
Cat 5/6 cable connections - straight thru both ends the same.
cross over cable - one end type A other type B
TYPE A
wt-or
or wt
wt grn
blu wt
wt blu
grn wt
wt brn
brn wt
TYPE B
wt grn
gn wt
wt or
blu wt
wt blu
cr wt
wt brn
brn wt
Color Table
wt - white
or - orange
blu - blue
grn - greeen
brn - brown
wt blu = primary color is white with a blue stripe color
blu wt is primary color is blue with a white stripe
Feb 09, 2013 | PC Connection Cross-Over Cable (363003X)
Industrial building built in '93. They used 277v (coming off one leg of 480v 3PH) for lighting high bay lights. The number on the line taps for pugging in the lights is: LDM2. This plugs into a G1...
Any electrical supply house should have the wire tap connectors. Your new load depends also on the current draw of the existing load, the wire size, and the circuit breaker or overload heaters on the circuit. If the total load is less than the rating of the wire and protection, then yes you can tap in without causing an overload condition.
Jan 26, 2011 | Heating & Cooling
My type 30 slows down when the tank pressure reaches close to 100 psi.. motor is new as this caused old one to burn up,, what can it be?
1. Are you sure the motor is wired for the correct voltage? If you have 230V 3PH,Make sure that you do have 3 hot legs. you should have L1-1+7, L2-2+8, L3-3+9 and 4+5+6 connected together. If it is wired for 480V it will not have enough torque. Check rotation. There should be an arrow on pully (large one on compressor)
Nov 03, 2010 | Ingersoll Rand - Rand Type - 30...
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
I have 3phase in my shop. I have a new machine that is rated for 208v 3ph. how can I tell what my incoming voltage is?
You will need to take the cover off of the breaker panel. Find the three lugs that the incoming hot wires are hooked to. With three phase you will have three hot lines. Check the voltage between the phases. L1 - L2- L2- L3- and L1 - L3 Also check the voltage from each line to ground. If you havw 120/208 three phase current you will have 208 +or- a few voltage between the phases and 120 or so from each line to ground. If you have 120/240 three phase you will have 240v across the phases and 120 to ground on two legs and 208 to ground on one leg, this is called a "wild" or high leg. You may also have 480v into the shop and you will know that very quickily if you get 480v between phases. No matter if you have another voltage, you can buy a trandformer that can convert whatever you have to 208/120 3 phase for your unit.
Nov 15, 2009 | Jackson 25 in. TempStar HH Free-standing...
Need to wire a new car stereo for ford 1991 fairlane i am having trouble working the colour coding of the old wires as alot of the new colours are different
colors are:
gry/grn + gry/blk -> rt frt
org/grn + org/blk -> lt frt
blu/red + blu/blk -> rt r
pnk/grn + pnk/blk -> lt r
+12V - grn/yel
+12v switch -> blu/wht
ant: ( if you have it) -> red/blu
lights: brn
earth- > blk
Sep 16, 2009 | Pioneer DEH-30MP CD Player
Need help with 2004 Hyundai Santa Fe Audio Wiring
Sounds like you need a light tester. I would guess that at least 8 of the wires are speaker + & - the others will be Main power and earth Possibly electric ariel, Memory store and a wire for the anti theft circuit. Assuming the stereo is factory. Any Audio shop can perform a test to clarify the purpose of the wires Wouldnt worry about the blank its probably a position for a newer or different model to yours. Steve in the UK
May 13, 2009 | 2004 Hyundai Santa Fe
Need to know wire colours
RADIO 12Vwhite |+ |radio
RADIO GROUND black |- |radio
RADIO SWITCH|white/black |+ |radio RADIO ILLUMINATE|red/yellow |+ |radio LF SPEAKER|brn/blk - brn/wht
RF SPEAKER|orange - org/blu LR SPEAKER|lt grn - lt grn/blk
RR SPEAKER|gray - gry/blk
Dec 26, 2008 | 1999 Suzuki Vitara
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
