Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Power will not stay on
Every time I use remote the light on the power button comes on for 2 seconds but the tv never turns on. Then when I manually turn on the the tv, the same thing happens. Sometimes the light comes on again, like it is trying to restart itself, but nothing happens.
  • 5 more comments
  • NMgurl Dec 06, 2008
    I have same problem, my tv will not come on, and I have the green power light come on and ten goes off for 2 seconds and this happens three times, and then it goes off for 90 secs. This process repeats its self over and over, and some how there a sizzling sound and that's it comes on. Use to be that the tv would come right away but it's getting to be 3 days now. Seems like the tv has a mind of it's own.
    I have the same problem, with remote and also manually the green comes on for 2 secs and then goes off and comes on again, this happen three times, then it goes off for 90 secs, and the whole process repeats itself again, but tv never comes on. you know it's coming on when you hear a cracklin/sizzlin sounds when it's coming on. Use to be it would come on after a few tries now it's like 3 days now and the tv seems to have it's mind of its own.
  • Kristovski Dec 18, 2008
    Yeah, I had a tech come check on my TV and he said I need a new power supply and deflection board. he got the part number: GE #043694 but said he doesn't think he can find it. Does anyone know where I can find that part? I haven't had any luck looking online. Thanks!
  • Anonymous Dec 19, 2008
    I have the same problem, with remote and also manually the green comes on for 2 secs and then goes off and comes on again, this happen three times, then it goes off for 90 secs, and the whole process repeats itself again, but tv never comes on. you know it's coming on when you hearit when it's coming on. Use to be it would come on after a few tries now it's like 3 wks now and nothing
  • Anonymous Jan 15, 2009
    I have the same problem i can it be fixed
  • Anonymous Mar 12, 2014
    When I go turn on the TV,the green light comes On and Off three times but nothing happens .
  • 106 Answers
You probably have capacitor CP150 bad on the power/deflection board. The capacitor is a 2200 microfarad at 16 volt cap. This component should be changed by a qualified tech
Posted on Dec 02, 2008
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I lost my code sheet. how do i get a new one.
Try to do this:
Guide to Programming the Remote
Follow these steps to program a device into your remote control. Thereare two ways to program your remote. If you already know the code foryour device, you can program it into your remote manually. If you donot know the code, you can use the code search function to program theremote control.
Using Code Search:
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button toprogram the DVD player, etc. The light on the remote control willblink and stay on.
5. Slowly press and release the power buttonrepeatedly until the device turns off. Each time you push the powerbutton the light should blink once.
5. Enter the code for your device using the number pad. The light willblink each time you push a button. If the code works, the light willturn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work,start from the beginning by holding down code search until the lightstays on and use a new code.
Ifyou used the code search function to program your device and want toknow the code for future reference, you can retrieve the code from theremote. To do this:
2.Press the device button for the code you want to retrieve. Press TV toget the TV code, etc. The light will blink once and stay on.
2. Use the number pad to enter 2 digits for how many minutes to use forthe timer (01 to 99 minutes). The light will turn off and start timing.
SOURCE
Sep 29, 2010 | Innovage Jumbo Remote Control
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Hello,I need codes to the remote!
Instructions on how to use the CODE SEARCH button:
In this example we will say we are setting up the TV button for our television set.
1. Manually turn the power to your television set ON.
2. Hold down the Code Search button on the remote for 2 or 3 seconds until the light on the remote stays on (aka stays solid).
3. Push the TV button on the remote.
4. Point the remote at your television and slowly press POWER until the television turns OFF.
5. Press the ENT button on the remote. (It is under the number 7 button.)
or for your actual codes, go to:
PHDVD5 CODES
http://www.replacementremotes.com/store/productdetailp.cfm?productid=6113
Jan 29, 2009 | Philips PH-DVD5 Remote Control
Ihave bought a GE universal romote control RM24948 and can not figue out how to set it up please help
Hiya this is how i got mine to work.Manually turn on the tv.Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Dec 15, 2008 | GE RM24948 Remote Control
Codes
May 20, 2008 | GE RM24948 Remote Control
Ge 94948 universal remote instrutios for progaming t.v.
Feb 19, 2008 | GE RM24948 Remote Control
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
