I have an issue with a network printer. I have a Brother MFC 8440 connected to a HP laptop with Vista 64 via a US Robotics 9108 wireless router with a USB/printer port. The printer works connected directly to the laptop and previously worked via the wireless router. However, it has now stopped working. I get a ?printing? status in the printer window which eventually becomes ?Error ? Printing?. This began happening sometime after my attempt to tweak my system, so obviously I did something stupid. I have deleted and re-added the printer with a TCP/IP address of http://192.168.1.1:1631/printers/My_Printer. When I access the router and check the printer status, it claims to be ready. I suspect there is a service or something that is either not running or I deleted, but I cannot find what it is. I am logged in as admin. Any help will be appreciated.
  • jt1942 Dec 04, 2008
    chessmaster2,
    Sorry for the delay, but notification was caught in my ISP's spam filter. Uunfortunately, your fix didn't work. I get a status - printing for a while, then it goes to error - printing. Nothing prints. I can Cancel all documents to clear the queue.
    Scholar:
  • 160 Answers
Check the print spooler under running processes/services. if it shows running. turn it off, wait until it shows not running and restart.
Posted on Dec 02, 2008
MFC - 5890 CN
If your printer and computer are Bluetooth capable then yes it can be done that way. The other way is through your wireless network/router. If you run a cable from you wireless router to your printer then you can use it wirelessly.
Feb 12, 2014 | Brother MFC Office Equipment & Supplies
How to connect hp pavilion to brother mfc9560cdw without router
This model Bother printer has a 10baseT LAN connection and can be connected to your LAN network and to your HP laptop via the wireless router. Connect a LAN cable from the printer to the wireless router.
To print from your HP laptop, check the IP address range your wireless router issues to your wireless network, it maybe 192.168.1.*** then configure the brother printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the Brother printer driver normally.
Then configure the Brother printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Brother
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Jul 07, 2012 | Brother MFC9560CDW AllInOne Laser Printer
Brother mfc-7840W not picking up wireless IP address
It is common, mainly because the MFC connection is lost to your PC. Are you able to print or scan from another wireless PC that you have? If yes, contact your network admin or router oem. If no, reset network card. Run the Setup Wireless Wizard. Make sure you have router info such as SSID, Network Security Key, Authentication Method (Open, Shared, WPA/WPA2-PSK), Encryption (None, WEP, AES, TKIP). Enter those info, it must be CASE SENSITIVE. Just in case you dont know your router info, contact your router oem.
For Advanced Users.1. Click your Wireless Icon at Task Tray2. Right-Click your Wireless Network Name3. Select Properties4. Go to Wireless Security Settings5. Take note of the settings that you have there and enter it again on your MFC
Goodluck! If you still need more assistance. Call us 1-877-Brother. :)
Jan 03, 2012 | Brother MFC 7840W Printer
Brother 8890DW Wireless Configuration Difficulties. I want to configure the above printer through a wireless acess point connected to a router via ethernet. The router sees the printer, yet the computers...
I don't have a solution, but I have a similar problem with a new Brother 8690DW MFC machine. Out of the box - I can't establish wireless connection. Brother "tech support" (!) insists I am typing in the WEP key incorrectly... doesn't matter to them that I've configured literally hundreds of devices with encryption keys before.
I'm about ready to return this machine and get another. Yet, I suspect that the Brother setup instructions are missing something I need to do - I can't figure out what, though, and have been through every relevant setting I can find.
Apr 13, 2011 | Brother MFC8440 Remanufactured Laser...
Hello, I have a brother MFC-490CW mult-function printer (wireless) and I am having trouble setting up the wireless feature so my laptop can print to it via through my home network (Linksys wireless...
You have to make sure the following are used on your wireless settings on your router -
Wireless Network Security SSID (32 chr), WEP 64/128bit, WPA-PSK (TKIP/AES), WPA2-PSK (AES)
This means your SSID is less than 32 chars and your running either WEP, WPA. Or WPA2
Then on your printer make sure you have the wireless enabled and Just a good rule of thumb - When putting in a wireless printer just fudge with the wirless/TCP/IP settings on the printer until you can ping the printer from the PC. Do NOT bother running the software installs until you know you have a good ping from the printer as it will just bomb out.
do rate the solution plz
Nov 25, 2010 | Brother MFC 490cw Color Inkjet...
Will no longer print via wireless network and indicates that it cannot find the printer
I just had this issue yesterday.
Step 1. Turn off your Brother
Step 2. Turn off your Wireless DSL/Router
Step 3. Turn on the Wireless DSL/Router
Step 4. Turn on your Brother Printer
Apr 06, 2010 | Brother MFC 7840W Printer
Can't get the printer to print while connected to a router
Hi! I will be glad to assist you in this issue. This is the link that will help you to fix the issue:
1. Installing the Product Software in Windows XP and Vista for a Wireless Network Connection (Using an Access Point)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01736948&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
2. Installing the Product Software in Windows XP for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708573&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
3. Installing the Product Software in Windows Vista for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01710137&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
4. Wireless & Network Issues Link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33412&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
Oct 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Vista 64 cannot print using USR5461 print server
sir chuck, try NETWORK MAGIC it can fix your problem from PRINTER & file sharing and others. It fix network problems regardless of Operating System , windows, linux, mac etc.
May 04, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I have a us robotics wireless model 9108 router. I have just bought a dell inspiron laptop with vista home premium and am unable to connect to the internet. can you help?
ushally you will have to set up your connection being connected to the router via the lan cable once you do that you can configure your laptop to be allowed to run on the wireless setting.
so if you have another computer hooked upto it you can set the permissions on that you have to create a new network for the laptop.
if you have the manual you can find the configuration settings for your router, most you just open up Internet explorer and then type in home to access this menu.
but for your unit im not 100% sure of the configure setup for it.
Aug 11, 2008 | Computers & Internet
Networking a Printer on a wireless network
Deanna, if the mfc is not that old, take it back to the dealer and ask for changing it to a wireless printer (extension: CW). Do you really need the fax function? If not, try this printer: DCP 750CW. If yes, get the MFC 845 CW. The CN printer have to be connected directly to router or pc/laptop.
Sep 27, 2007 | Brother MultiFunction Center MFC-440CN...
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
