Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Wall heater not working properly--sputtering blue flame
My 30,000 btu propane wall mounted heater was working fine till yesterday, when it started sputtering, and having a blue flame on the tiles. The last tile seems like it does not even want to light up, and just puffs off and on. I took off the long tube at the bottom, and the little holes are all opened for the gas to get through. I also used air to blow the tube clean, but did not find any blockages there.
Any suggestions?? Thanks in advance for any advice I can get on this. I also tried another full 20 lb. propane tank, but with the same results.
    President:
  • 3,433 Answers
Ok, either your fuel pressure is too low or too high.. When you light the unit, Light it in low, then turn it up slowly Just crack open your tank valve.about1/4 turn. The air in the tubes has to be displaced with gas before you get a good flame
Posted on Nov 11, 2009
Our Blue Flame Natural Gas 30,000 BTU Stove Smokes the wall above it all the way to the ceiling and keeps the wall very hot, this is the second one we have tried, has anyone else had this problem?
It comes from the factor ready to use PROPANE, if you are using natural gas, then it needs to be re-jetted or orifices changed for the proper gas.
Jan 17, 2016 | Mr. Heater Heating & Cooling
I have a two year old Redstone 30,000 BTU propane wall heater. There is a lot of dust behind the unit. After running for awhile on the 2 setting, it shuts down and the pilot is extinguished.
If it is a wall unit, it has an over temp safety switch which is most likely tripping from dust preventing proper airflow across it . A good cleaning should cure this.
Feb 04, 2015 | Heating & Cooling
The heater ignites well, but if it gets a clear blue flame (and it burns very quiet), the thermocouple will glow red and the heater stays on, but when it gets a opaque blue flame (it makes a sound when...
I would start by replacing the thermocouple. It is suppose to keep the gas valve open when in operation. If the mercury in the thermocouple dries out it won't keep the gas valve open and thus the flame goes out. If that does not work then you have a gas valve problem.
May 05, 2017 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
My 35000 btu will not stay lit. after i take my finger off the propane gas butten the flame goes off. what is wrong. this is a ready heater
I would venture to say that it is the thermocouple not picking up signal to keep the gas valve open. You can try cleaning the bulb end with steel wool and positioning it in the flame remember the hottest part of the flame is out on the end.
Dec 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Heating & Cooling Logo
588 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
